Oil in coolant - Ford Truck Enthusiasts Forums
Oil in coolant
Old 01-07-2014, 09:27 PM
Luggy Luggy is offline
Luggy is starting off with a positive reputation.
Oil in coolant
2003 f250 6.0 of course. I have oil in the coolant in reservoir however no coolant in the oil I am assuming that would be standard as the oils pressure is higher than the Coolant pressure. I am not losing any oil from the engine or at least if so it is so minimal that I haven't been able to tell it. I bought the truck and it had 120,000 miles on it. It has had some work done at the dealership earlier in its life. Just wondering if a coolant flush would be my best bet to do first to see if maybe it is still dirty from previous problems. Keep in mind I am not sure if the oil cooler ever been changed just the fact that I am not currently losing oil and the oil is not milky I am hoping it's not as bad as it seems.
Any information that any of you could give me would be great.
Thanks
Old 01-07-2014, 10:04 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Sorrey Man But its BAD
Stop Driving it
Oil cooler Blew you need a New One
You will have to Stuff a Hose in it when its Apart to flush as much as possible oil out of coolant
Old 01-07-2014, 10:16 PM
holdtyte's Avatar
holdtyte holdtyte is offline
holdtyte is starting off with a positive reputation.
I work at a CAT dealership. We use Calgon to flush oil from the coolant systems. Works well but it all needs to be flushed out afterwards
Old 01-07-2014, 10:50 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
How long have you owned the truck?
Coolant Puke - What am I looking at? nmclella 6.0L Power Stroke Diesel 10 12-29-2015 11:10 AM
Coolant Loss mwoolard1912 6.0L Power Stroke Diesel 4 01-07-2015 09:08 AM
IDI van "disappearing" coolant Gettysburg150 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 10-28-2014 04:04 PM
MY COOLANT PROBLEMS CONTINUE, DAG GUM IT !!!!! StanleyZ 6.4L Power Stroke Diesel 51 10-26-2014 10:30 PM
Coolant Pressure Fluctuations/Losing Coolant sherLocke9 1987 - 1996 F150 & Larger F-Series Trucks 11 03-04-2014 08:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
