1988 F150 $1175 for fuel pump??
Hey all,
I need some help quick! Please. 1988 Ford F150 351 auto with dual tanks.Took my truck to the mechanic as it completely bogs down when the accelerator is pressed. It barley goes and sputters and pops. Mechanic called and said it was the fuel pump on the rail and possibly the regulator. Said it would cost $1175 to repair and that might fix it. Said fuel pressure was 8psi. Thoughts, ideas,?
Lead Head,
Thank you for your help. I cleaned the iac, throttle body. I did learn to pull the codes first. I got
KOEO--33 EGR and 51 ECT Sensor which I replaced
CC 33 and 51
KOER 33, 51, 98-system in back up mode..I did not understand that one. I have never dealt with the fuel delivery system except for fuel filters. I will start learning now. Thank you very much for your time.
CC 33 and 51
on
Just FYI fuel pressure at idle should be about 40 psi. If you have changed the fuel filter, and if it does not make any diff which tank you are on when this happens, then the external fuel pump is most likely the culprit. The regulator cannot cause low pressure, it causes high pressure if it fails. You might check your fuel lines to make sure you do not have one collapsed or kinked although that is very rare.
Thanks to all
I am going to go get a gauge to test fuel pressure. I don' t know much about fuel delivery, but I have been following posts for a long time. The mechanic told me there was 8psi at the rail. I asked him what it should be. He said 18. Having followed posts here and on fullsize bronco, I knew the number should be at the least in the 30's based off memory. Thank you, jass88. If you every head to Canton, Ga, let me know, I will make sure you don't go there.
The Ford Part for the Pump is 9c407 for $536! Wow
Anybody know a reliable after market pump?
You can buy a Delphi external high pressure pump for $88 + shipping from rockauto,com. The in tank pumps are about the same. Stay away from Airtex & the economy pumps. I use Delphi pumps in everything I have to put a pump in. I have yet to have one fail prematurely.
Yep..
rla2005--Thank you for checking that part and price
joey2fords--yes, I know every one has to make a living but...One job I have been putting off is fixing the ignition actuator, know how but just haven't wanted to tackle it yet--I asked them for a quote..wow.. I must have looked like an easy mark.
I don't know if you checked it or not, but some of those trucks have a filter in the tank selector valve. It may say "Non-servicable, Do not open" on it. THEY LIE! I bought a new one and about a year later, my truck did just this very thing. I tried a bunch of stuff and nothing worked. My friend ask about the filter in there and I said "no it doesn't have one, it is a sealed unit." Well guess what! Took out that stupid filter, threw it as far as I could, and no more problems. BE CAREFUL with the o-ring! You cannot get one from Ford.
