1988 F150 $1175 for fuel pump??
Problem Discovered, (not by me of course), but I am learning
et_miller_87 nailed it and so did eakermeld. My tank selector switch had shorted, melted and fried. It looked good at a glance but I would have seen the damage had I spent more time there and not had tunnel vision on the fuel pump. That short at the switch shorted out quite a bit of other things as well. et_miller_87---I will start learning about the electrical. You were right about low current. eakermeld--the mechanic said if the electrical had not got me, the cannister would have. Thank you all very much for your guidance.
Who do you use? I'm in Dawsonville as well. I usually use Mullinax in Dahlonega for the stuff I don't want to do.
Grantslicker, something to look into,as a general rule, check for codes first. Even if the CEL isn't on, there might be codes in CM. Another direction to go is to check all the vacuum lines, check the spark plugs for a bright blue, healthy hot spark. And just because you've got good fuel pressure doesn't mean you don't have a fuel delivery problem. Clogged injectors could be a culprit in some cases.
So it was the actual selector switch that was shorted? My 351 runs fine until you need to accelerate or go up a hill, then it sputters and occasionally backfires thru the intake. I tested the fuel pressure at the rail and it was within specs. I'm about ready to throw in the towel til spring. Any advice is appreciated.
#28
35psi at idle, 45psi at WOT. There was a filter in the valve that wasn't supposed to be there. It was plugged up. That was the new, one year old one. The original valve was letting fuel pass between tanks. After I replaced it I took it apart and found some gunk under one valve. Be VERY CAREFUL removing that bowl from the selector valve. You cannot buy replacement parts like o-rings and such.
#30
Well, I did a fuel pressure test today, my results were:
Engine off 38 psi. (Ok)
Engine idle 33 psi (ok)
Engine idle vacuum disconnected from FPR 42 psi (ok)
Turn off engine and at 1 minute pressure drops to 20 psi (failed). It didn't take long to drop to zero. I also noticed a small amount of fuel in the vac line.
I'm in the process of removing the FPR, what a PITA that job is! Basically have to remove the fuel rail. I sure hope this makes a difference.
