Dual Exhaust And Mid-Ship Tank
The normal set-up for true duals is one on either side of the drive shaft the mid-ship tank hangs down and is about flush with the bottom of the frame and is just inches from the driveshaft. I had that idea with a 77 my grampa had but I scrapped it because it was a Custom with only one tank and it was midship
1979 F-150
302 C-6
sc/lb
1979 F-150
302 C-6
sc/lb
Are you asking about a 73-79? ive got dual exhausts on two F250 highboys both with stock exhaust manifolds, and both with the tanks that are right behind the cab, just outboard of the drivers side frame rail........I dont know what works on a 2wd, an F100/F150, or a 77-1/2 to 79 F250 4x4........Please specify exactly what youve got, because otherwise we are just guessing
you could probably cross your drivers side exaust over behind the engine cross member run both down the passenger side and cross the drivers side back over behind the rear Axel. it wouldent be ideal as your drivers side exaust would be longer than your passenger side but it would work. aether that or you could dump your exaust to the ground at the back of the cab depending on how close it came to the fuel tank you might consider a heat sheild
on 2wd and NON highboy 4wd's, the frame is wider so the tank is inside the frame. this means with long tube headers, the collector is pretty much pointed at the mid tank on the drivers side, mid length headers have a chance at curving to the passenger side when building the exhaust.
https://www.ford-trucks.com/forums/1...ence-pics.html
thanks to HIO Silver for the pics
Ford did not offer dual exhausts for these trucks. The only trucks that came with dual exhausts were the Lightning models introduced in the late 1990's. Both pipes exited out the right (passenger) side.
ALL factory installed mid-ship and aft axle tanks are mounted on the inside of the left frame rail.
I have read on here about aftermarket tanks on the outside of the framerail, that was a quiet assumption about what iggybob44 and Chevmn56 were talking about. there are threads on here that have pics of different exhaust routing, the one I am describing (badly) is silver or aluminized, goes under bellhousing from driver to pass side with two glasspacks(?) offset from the other to a handmade NASCAR type collector in front of rear wheel
