Connecting tranny cooling lines to aluminum radiators - Ford Truck Enthusiasts Forums
Old 01-07-2014, 12:46 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
I was thinking about the steel lines to aluminum connections on aluminum radiators....should I have a brass connector between the two?
Or is it normal practice to connect them directly. My concern is the aluminum being softer than steel and wear-n-tear on the radiator connector.
Input please? Thanks!
Old 01-07-2014, 01:13 PM
Normalbloke Normalbloke is online now
Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.
I'm running a 1/8npt to AN6 adapter in the rad end, this is blue anodised aluminium. I'm then running AN6 braided line to the trans. No steel in it anywhere apart from the braid. But I'm seriously thinking of doing away with the integrated cooler in the rad and having a standalone cooler on the front or under the truck somewhere....
Old 01-07-2014, 02:00 PM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
We just used AeroQuip steel fittings and a Got-to-Show lines kit.
Gotta Show Products Home Page Featuring Hot Rod Plumbing
Old 01-07-2014, 02:14 PM
Holehawgg's Avatar
Holehawgg Holehawgg is offline
Holehawgg is gaining momentum as a positive member of FTE.
I'd throw a short braided line or rubber line a vibration isolator between the two. Why chance it.
Old 01-07-2014, 02:21 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
You'll need some interface to go from the flared steel to the NPT threads in the radiator. A brass adapter will prevent dissimilar metals corrosion. As long as the steel lines are mounted so that they can move around it'll be fine. AN fittings are definitely better, but millions of Ford cars went out of the factory with steel lines....it should work for you too!!
Old 01-07-2014, 02:44 PM
Quote:
I'm glad I asked....
I didn't know the radiator was NPT..
There are no stupid questions right?
Old 01-07-2014, 02:46 PM
AWE!!! Chuck ****! no...I mean...TRUCK ****!!!
Chuck that looks great!!
Chuck, Is that a Superior Radiator from MT Clemens, MI ? Looks like it. Thats what old_dan and I have.
Old 01-07-2014, 03:20 PM
ChuckRob's Avatar
Nothing like a little Truck **** to get you going in the morning. Yes that is a Superior radiator and shroud from Mt Clemens
ANY luck with an aluminum radiator? norm805 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 11-18-2015 04:17 AM
Regular cab drive shaft material raven3 2015+ F150 5 10-23-2015 07:46 PM
FACTORY ALUMINUM WHEELS 5X5 1987 - 1996 F150 & Larger F-Series Trucks 12 01-26-2015 12:35 PM
Aluminum ignition switch link thingy? BruteFord 1987 - 1996 F150 & Larger F-Series Trucks 23 12-10-2014 06:12 PM
Help with new radiator. Project Completed! akamacgyver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 62 08-26-2014 11:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
