Thoughts on a block heater? - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-09-2014, 06:50 PM
Shoo12's Avatar
Shoo12 Shoo12 is offline
Shoo12 is starting off with a positive reputation.
It certainly wasn't warm to the touch but it was about 15 degrees this morning. Does it really keep it that warm that the outside of the block would be warm to the touch in these temps? Any idea on how ohms of resistance or just any amount of continuity it's working?
Old 01-09-2014, 06:54 PM
Booma Booma is offline
Booma is starting off with a positive reputation.
Quote:
Originally Posted by bubbasz1 View Post
The NAPA cord is just that, a cord, the ford one is wrapped for protection, I used that plastic covering for harnesses, worked fine.
I'll take your word that the Ford cord is wrapped with something (heat protection?). However my Ford dealer wanted $121 for it and Amazon sold the NAPA cord for $11.20. I think I can wrap it in a heat shield for a lot less than $110.
Old 01-09-2014, 07:28 PM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
Quote:
Yep, that's the way I saw it also.
Old 01-09-2014, 07:47 PM
bubbasz1's Avatar
Quote:
I don't know about warm to the touch but yesterday I did a little experiment at work. Got to work at 5AM, -6 degrees outside. I plugged in later that morning and checked and recorded the vital information. I checked it every hour or so after until I left Work. I appears that the best your going to get out of the block heater is about 75 degrees or so, pretty much leveled out after 4 hours. I would thick if you had continuity it's working, but electrician I'm not.
Time ------ Oil Temp ------ Water Temp ------ Outside Temp
11:00 ------ 40 Degrees ------ 40 Degrees ----- 2
12:00 ------ 53 Degrees ------ 68 Degrees ----- 2
1:20 ------ 66 Degrees ------ 78 Degrees ----- 2
2:20 ------ 68 Degrees ------ 77 Degrees ----- 2
Outside temp was per the truck external temp sensor, water and oil temp was from my H&S.
Old 01-09-2014, 08:51 PM
Vinford's Avatar
Vinford Vinford is offline
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
You touch around and you can feel it.
It will even melt the frost off some hoods.
Old 01-09-2014, 09:55 PM
longview1's Avatar
longview1 longview1 is offline
longview1 is gaining momentum as a positive member of FTE.
Stick your head in the pass. side fender well and you can hear it.
Old 01-09-2014, 11:09 PM
URDADDY's Avatar
URDADDY URDADDY is offline
URDADDY is starting off with a positive reputation.
Just my opinion but with the 6.4 you probably don't need it unless you see -5 plus on a regular basis. That being said I also don't need it, but have it. For the price it is nice to have available. Also bought on amazon and have an extra cord if anyone needs it. Shipping cost and its yours.
Old 01-10-2014, 08:59 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM BROWN DOG KTM is offline
BROWN DOG KTM is gaining momentum as a positive member of FTE.BROWN DOG KTM is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by tgreening View Post
That's because you live in Georgia. It was -11 this morning ...
It's been 6, that's SIX Degrees here in North Georgia this week Thank You
South Georgia has Florida weather.
The 6.4 Block Heater cord is pretty difficult to twist lock to the Element behind the starter but is doable
Old 01-10-2014, 08:52 PM
Tawn's Avatar
Tawn Tawn is offline
Tawn is gaining momentum as a positive member of FTE.Tawn is gaining momentum as a positive member of FTE.
This past week we had several single digit nights. When I plugged it in, the glow plug indicator was only on for 3-5 seconds. When I didn't plug it in it took about 10 seconds for the indicator to go out.
When plugged in it was blowing warm air within 5-8 minutes of normal driving, when it wasn't plugged in, it took about 12-15 minutes before it warmed up enough to turn up the blower.
FYI - I didn't have the time to install the cord myself. The local ford dealer charged $220 out the door to put the cord on (parts + labor).
Old 01-10-2014, 10:49 PM
ssharber's Avatar
ssharber ssharber is offline
ssharber has a good reputation on FTE.ssharber has a good reputation on FTE.
I live in TN, and I love my block heater. Not only for the fact that it keeps the engine AND the oil warm, it helps keep my garage warm also. You definitely know when mine is plugged in cause the hood is warm to the touch. Some might say that I'm a fool for keeping it plugged in even though it is garage kept, but it makes a tremendous difference in how my truck drives when I start it up and pull out in the cold. Especially lately in the single digit weather we've had. I also feel it has helped my engine oil analysis's with some of the lowest metal numbers amongst the many friends I have who also have their oil analyzed yet DONT use theirs. A warm engine is a happier engine. Especially at startup. It's definitely worth it to me. Just my 2 cents worth.
NEWER STYLE 6.7 TAP SHIFTER FOR 6.4 BY BD DIESEL SANDDEMON08 6.4L Power Stroke Diesel 8 05-06-2015 10:24 AM
2008 F250 heater core replacement help ispeed77 1999 to 2016 Super Duty 2 12-30-2014 06:53 AM
Is a diesel ideal for long commutes? BrianDye General Diesel Discussion 17 07-21-2014 12:14 AM
6.4 oil and fuel filters for sale wingedone Ford Truck Parts for Sale 0 04-10-2014 01:05 PM
6.4L EGR DELETE shopguy5646 6.4L Power Stroke Diesel 0 04-07-2014 12:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
