King Pins - Page 2 - Ford Truck Enthusiasts Forums
King Pins
Old 01-18-2014, 01:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I've seen that process, and similar, described on the HAMB. About the best you can hope for is to make it oval in a way that the kingpin won't rattle around. It's not a "fix". I have to believe there are good axles close by you for little money.
Old 01-18-2014, 02:41 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
It takes a great deal of skill, experience and understanding to "shrink" the boss as you describe. There is a much better chance of stretching the boss instead, making it useless, and/or changing the temper of the metal. As said, axles are cheap, and most are good.
Old 01-18-2014, 02:53 PM
petemcl's Avatar
petemcl petemcl is online now
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Quote:
Originally Posted by Steve View Post
Well I got the spindles back from the machine shop, and they charged me $60 which I thought was fair considering he used a honing machine so they came out about as good as they get. I still have the hourglass shaped axle bosses to deal with. I read about heating the axle boss, then inserting an old but good pin in the hole then peening the upper and lower portions of the axle boss to effectively shrink it. Anybody done this?
I agree with AX . . . It sounds very dangerous. You stand a good change of embrittling the metal on a very critical part. As Ross said, just replace the axle.
Old 01-18-2014, 03:06 PM
ALBUQ F-1's Avatar
postin' fool
Heat isn't necessary. You would have to get it really bright-red hot to change the metallurgy. The axle I posted was done cold. If it were done hot enough for the metal to work easily, the shape would be changed dramatically with one good shot, and not in a controllable direction.
Old 01-18-2014, 05:04 PM
Steve's Avatar
Steve Steve is offline
Steve is gaining momentum as a positive member of FTE.Steve is gaining momentum as a positive member of FTE.
Thanks for the input. I'll start looking for a better axle.
I'll try to post a video that shows the actual play.
Old 01-18-2014, 05:25 PM
ALBUQ F-1's Avatar
postin' fool
If we could see it in a video, it's too much play.
Old 01-18-2014, 05:28 PM
Steve's Avatar
Old 01-18-2014, 05:49 PM
ALBUQ F-1's Avatar
postin' fool
They're both loose, the left is pretty bad. Ideally you'd have to at least push them thru, if not tap lightly.
Old 01-26-2014, 02:27 PM
Steve's Avatar
I found a very nice axle at a swap meet. Nice tight holes (!)
Are these axles symmetrical, allowing installation either way, or is there a king pin inclination? Hard to tell by looking at it on the garage floor...
Old 01-26-2014, 02:31 PM
ALBUQ F-1's Avatar
postin' fool
Yes, kingpins are tilted forward at the bottom
Old 01-26-2014, 02:39 PM
Branded Branded is online now
Branded is gaining momentum as a positive member of FTE.Branded is gaining momentum as a positive member of FTE.
Or tilted back at the top..
Old 01-26-2014, 04:08 PM
Steve's Avatar
Is this inclination built into the axle or does the tilt happen when attached to the spring?
  #28
Old 01-26-2014, 05:25 PM
AXracer's Avatar
Both.
  #29
Old 01-26-2014, 07:29 PM
ALBUQ F-1's Avatar
postin' fool
Stick a broom handle in the kingpin boss, it will be obvious
  #30
Old 01-26-2014, 09:08 PM
Steve's Avatar
To check using the broomstick method I guess I could try to get it into a vise until the mounting pads are level. I was putting the pin in there and eye-balling it against a speed square but it looks very close to 0 degrees that way. I guess an inclinometer would be helpful. Is 2 degrees enough in a stock spring set up?
I replaced the pins and bushings in the springs and frame so now the springs don't move sideways anymore. Funny how this king pin job snowballed on me. Shoulda known...
Anyway, how much inclination is built in to the axle? One needs to know how to recognize that to determine which way of the beam faces forward? Or is there another way to tell?
New to Body Repair Seeking Advice Steve Paint & Bodywork 6 11-21-2016 11:39 AM
Intro and Aftermarket Parts Steve 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-14-2016 03:43 PM
Transmission drain plug Steve 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-14-2015 09:04 AM
'56 F600 Steering Box in a '56 F100 Steve 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 07-14-2015 08:39 AM
Old Boy Still Working Steve 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 04-09-2012 03:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
