Brrrrrrrr, its cold - under the hood!
#31
What type of connection do you use from trailer to the truck for the batteries.
I have 10ga wire from battery to the power source of the 7pin trailer plug, but that's not enough when I'm using my 12k winch.
I've wanted to put the dual alternators on my psd, the superduty has a second alternator control wire so the ecu can control the charge rate/load of each alternator. But the block bracket is tricky to find when I have the money.
I got a 200amp alt so I'm not too concerned about it right now, I want a York compressor more than a 2nd alt.
#32
My camper has some sort of charge controller for those batteries, I've never messed with that setup.
I try to overbuild my work stuff. If it fails once (usually when I need it the most) it irritates me and gotta build it bigger/badder next time.
#33
#34
I also have the 203 stat (about 4 years now) and agree with your observations. It's a timing thing. Here is a thread I did awhile back showing showing the EOT vs stock water temp gauge that you might find interesting ...
https://www.ford-trucks.com/forums/1...servation.html
#35
#36
#37
Thanks Jim. I'd say those numbers are pretty good. I hope I see the higher end of that Thursday and Friday driving across country. If definitely sounds different...a different kind of clackety.
