Can a stock '54 rear suspension tow a teardrop?
I have a 54 f100 with an '89 Mustang 302 5.0 engine, an AOD tranny, front brakes and rear axle from the same car, and most everything else is stock. Original steering, old leaf spring suspension front and back. So, can I tow a teardrop, or will the back end be too bouncy?
I'm just starting to build the teardrop on a 4 x 8 Harbor Freight trailer that can handle 1700 lbs, but I expect maybe 1000 lbs when it's done. (Have not picked out a plan yet)
Do i need to modernize the rear end with a drag link or something? I know my engine/tranny is not very torque-y, will that be a problem? Any other tips, ideas, or pitfalls that you guys can think of? Thanks! Jerry
Back in 1955 my family towed a house trailer from NY to Texas with no problems, with a '54 Ford 239 V8 and Fordomatic. The car was stock except for overload springs. We hit a detour in Chatanooga and had to go up a very steep hill. And up we went, about one mile per hour. The car had high mileage when it was traded and ran fine.
Remember these were WORK trucks as long as you use a suitable hitch (class2 for your load) attached to the frame, not the bumper or crossmember you could tow the space shuttle. (well maybe not uphill ) Biggest problem I can see is getting the hitch drawbar/ball low enough to level the trailer. You may need to modify a draw bar to bring it down low enough.
I used one of the harbor freight/Northern tool 40x48 trailer kits to build a race tire and tool trailer for autocross before I got an enclosed car hauler. I put well over 100K miles on that little trailer (often at speeds not to be mentioned in public)!
Two recommendations: I don't know if there is a choice of wheel sizes like there was on my trailer, but go with the 12". Northern Tool sells high speed replacement hubs with bearings that I'd use. Pack the hubs full of automotive wheel bearing grease for use with disk brakes, and repack one a year.
The two weak points that are not likely to affect you is the taillight brackets and the fenders crack and fall off from vibrations, and the incandescent light bulbs fail very frequently from vibrations. I replaced the marker lights with LED versions and replaced the taillights with a LED light bar that incorporated tail, stop/and turn functions that I mounted in the center of the rear. That solved the blown bulb problem and scraping of the shins from running into the license plate under the taillight. I used a polyethylene plate mount and an LED license plate light. I got all the lights from www,superbright.com
Here's a pic of my trailer with 2 sets of race tires on it:
The 54 Effie will haul a full out camp trailer, you might even forget you have a Tear Drop trailer behind you.
jmcder53
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
20
03-21-2019 04:35 PM
Pastor Scott
1999 to 2016 Super Duty
25
11-11-2016 09:28 AM
Holehawgg
02-06-2015 02:03 PM
