Speedo cable at transmission
Old 01-06-2014, 04:29 PM
benbuilder's Avatar
benbuilder
benbuilder is offline
How do you remove the speedometer cable from the transmission. I have removed the retainer clip but cant seem to see what holds in the cable. I do see from the ford shop manual, that there is an o ring inside. I cant believe that this alone would be so difficult to remove it. Unless rust is the answer. From the manual it does not appear that there is any other fastener. It is an automatic.
Old 01-06-2014, 04:39 PM
79FordBlake's Avatar
79FordBlake
79FordBlake is offline
Sometimes it does take quite a bit of effort to make that o-ring let go and come out. Takes a little to get it back in to. I had to yank on my speedo cable pretty good last time to jar it loose.
Old 01-06-2014, 07:11 PM
B.Petry's Avatar
B.Petry
B.Petry is offline
Dealt with this today . Just kind of wiggle it side to side with outward pressure on it . It will come out . If nothing else find a four year old kid . They can take anything apart .
Old 01-06-2014, 10:09 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The o-ring (87036-S94) on the speedo cable prevents fluid from leaking from the trans. Available from Ford, the same one has been used since 1950.
Old 01-07-2014, 02:47 AM
benbuilder's Avatar
benbuilder
Thanks everyone. I will keep at it today.
Old 01-07-2014, 06:04 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
Try constant pulling pressure, not to excessive, and try a rotating or circular motion as you pull. Sounds weird but it will work.
Old 01-07-2014, 01:47 PM
benbuilder's Avatar
benbuilder
OK guys, vise grips or channel locks ok? Or not a good idea?
Old 01-07-2014, 02:24 PM
77&79F250's Avatar
77&79F250
Dry shop rag and the circular motion I stated....
It that does not work, use a shop rag and a #2 flat tip and wrap the rag around the cable and twist the rag with the screwdriver, like making a tourniquet and then pull.
You do not want to crush the outer cable.
Old 01-07-2014, 03:03 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Wow!! Ya would think it would be worn out by now Bill.
Must be Ford tough
Old 01-07-2014, 03:16 PM
rockittsled's Avatar
rockittsled
rockittsled is offline
Must be Ford tough
DONT MESS UP MY CABLE!! its my turn next!!
Old 01-07-2014, 03:41 PM
arctic y block
Well take care of it as it's been in use since 1950. LOL
It's got to be American made for sure.
coppertales
10-06-2015 10:49 AM
saltbranch
09-21-2010 07:03 PM
72sportcustom3906.4l
06-20-2009 05:56 AM
hemiyota
05-06-2006 06:56 AM
hemiyota
05-05-2006 11:39 PM
Quick Reply: Speedo cable at transmission
