Carb Linkage - Ford Truck Enthusiasts Forums
Carb Linkage
Old 01-05-2014, 10:37 PM
alamartina's Avatar
alamartina alamartina is offline
alamartina is starting off with a positive reputation.
Carb Linkage
Hello to all.
I have a 215 c.i.d. OHV. There is a small link that goes to the carb from the pedal linage ( right behind the carbureted). One end is round and slips over the ball end of the linkage directly to the carburator. There is a clip and spring in the shaft of this link. Every now and then it slips off and the engine goes full throttle. Anyone know how to get it to stay on, or where I can purchase a new one!
Also, my starter cranks and then winds or spins. I'm assuming it's the starter. Is there a particular part of the starter to replace or am I looking at replacing the starter?
Thanks in advance for your help.
Old 01-05-2014, 10:50 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
The spring inside is likely broken or worn out. Could also be the ball on the carb linkage. Maybe it's worn. Napa may have a replacement. If not, I may have a used one.
Old 01-05-2014, 11:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
The part number appears to be TRAA-9772-A, shows as 2.10" long? One available...
Old 01-06-2014, 06:38 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by alamartina View Post
I have a 215 c.i.d. OHV. There is a small link that goes to the carb from the pedal linkage (right behind the carburetor). One end is round and slips over the ball end of the linkage directly to the carburator. There is a clip and spring in the shaft of this link.
Every now and then it slips off and the engine goes full throttle. Anyone know how to get it to stay on, or where I can purchase a new one.
It appears you want basic part number 9772.
Complete part number TRAA-9772-A .. Rod Assy-Bellcrank to Carburetor / Obsolete
1952 F1/F5 215 I-6 / 1953 F100/600 215 I-6 / 1954/56 F100/600 223 I-6 S/T & O/D.
NOS PARTS LTD in Waxahachie TX has ONE = 972-937-2201.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
Lower pic:
Old 01-06-2014, 09:47 AM
alamartina's Avatar
Amazing the amount of knowledge and information at this site. Thank you for your responses. Very much appreciated.
Old 01-06-2014, 10:01 AM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Try cleaning the bendix. Examine it for wear. They must be clean and free from heavy lubrication to work correctly.
Old 01-06-2014, 11:57 AM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
Couple of quick notes:
If the engine goes into full throttle, MAKE SURE YOU HAVE A GOOD RETURN SPRING! I totaled one of my 54's when it stuck full throttle due to a mechanical failure. Autozone, etc. sells a universal return spring if that is an issue.
As for the starter. They use a bendix that can and does get weak and fail. I actually found that the ones on 6 cylinder Ford tractors of the same era use the same bendix drive and often available at local tractor stores for less money.
Old 01-06-2014, 01:17 PM
alamartina's Avatar
The link itself falls off. I'm going to order one as shown in a previous post.
What does the Bendix look like?
Old 01-06-2014, 01:43 PM
raytasch's Avatar
The bendix is the end of the starter that has the screw, spring, and gear.
A temporary repair to the link may be made by squeezing and compressing the end where it falls off the ball. Pliers would be the tool of choice.
Old 01-06-2014, 01:55 PM
ALBUQ F-1's Avatar
postin' fool
There is an "improved" design Bendix out there, no personal experience, other than the old one is a PITA. Shop around, this is the first place I found with it: BENDIX DRIVE, STARTER - Starters - Flathead Ford Performance - Hot Rod Parts
Old 01-06-2014, 02:30 PM
What does the Bendix (11350) look like?
Old 01-06-2014, 05:03 PM
alamartina's Avatar
Thank you. Is this the same Bendix/ Starter for a 215 OHV?
Does the Bendix install on the front end of the starter?
These diagrams are great. What maintenance manual are they from?
Thanks again,
Old 01-06-2014, 05:10 PM
51PanelMan's Avatar
Quote:
That appears to be a bendix for a 239 flathead. I know this because I had to replace the spring in my 51 with the 239 engine.
The 215 starter bending is slightly different. I'll EDIT this post with a picture later today.
EDIT: Here's the starter Bendix for a 215/223.
Old 01-07-2014, 09:55 AM
alamartina's Avatar
Thank you for the pic. I assume the bendix can be replaced separately?
A fairly simple task?
Old 01-07-2014, 10:13 AM
ALBUQ F-1's Avatar
postin' fool
Yep, it's pretty easy.
Best and worst purchase of my life - 1978 f150 TheSterling 1973 - 1979 F-100 & Larger F-Series Trucks 16 02-13-2016 12:41 AM
'71 f100 electrical help, dcaudet 1967 - 1972 F-100 & Larger F-Series Trucks 26 03-11-2014 05:35 AM
AOD TP (throttle position) Rod or linkage Leeboy1962 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 02-23-2014 03:48 PM
Throttle linkage retainer clips Nothing Special 1966 - 1977 Early Broncos 13 11-11-2013 10:53 PM
1982 4 speed overdrive manual clutch linkage parts The_Builder 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 06-21-2013 02:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
