Carb Linkage - Page 2 - Ford Truck Enthusiasts Forums
Carb Linkage
Old 01-07-2014, 09:19 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Yes, the bendix can be replaced and it's simple. You have to remove the starter to do it. The starter is attached with two long bolts that go through the housing. Do not remove the bolts from the housing. You should be able to back them up enough to unattach the starter from the hogs head.
If you can't find a replacement bendix, I have several used one that I can send you to try.
Old 01-07-2014, 09:56 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1CM-11350-C .. Starter Bendix / Obsolete
1952 F1/F6 & 1953 F100/600 215 / 1953 F100 215/239 with F-O-M / 1954/56 F100/600 & C500/600 all I-6 & V8.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
ANTIQUE AUTO SUPPLY in Arlington TX has 35 = 817-275-2381.
Note: A roll pin retains the drive to the armature. To gain access to the pin, the drive has to be unwound by hand.
Old 01-07-2014, 10:47 AM
alamartina's Avatar
alamartina alamartina is offline
alamartina is starting off with a positive reputation.
So, I know obsolete parts can be costly. In this case (the carb link), I spoke with both companies in Texas. One would charge $8.00 but can't find it, and the other wants $40.00. I also found a TRAA-9772-C but it is 4" long vs. the 2.1" of the -A. The 4" one is $10.00. Seems the $40.00 price tag is high?
Panelman, you mentioned you may have a used one? Forgive my question, are you able to tell its condition in so far as staying on? If you have a reasonable confidence in its useability, would you be willing to sell and at what cost? I appreciate your consideration.
Old 01-07-2014, 11:18 AM
51PanelMan's Avatar
First, I think $40 is not unreasonable for a part that is specific and hard to find. Any 215/223 engine specific part is hard to come by. Second, I'm not 100% sure that I have the part and only guessing because I've had several engines that I've parted out. Third, if I do have the part, I wouldn't know the exact condition. I can only provide you with pictures if I am able to locate the part in the next few days. It's a very small part that could be hidden at the bottom of the many parts bins that I have.
I'm not trying to be harsh, but if it were me, I'd bite the bullet and buy the $40 NOS part. Your other option is to buy the 4" carb link, then shorten/weld to the correct length.
Old 01-07-2014, 11:23 AM
alamartina's Avatar
Thank you. You're not being harsh at all. I appreciate straight forward answers.
I'll bite the bullet.
Thanks for you thoughts.
Best regards,
Tony
Old 01-07-2014, 12:21 PM
1952henry's Avatar
1952henry 1952henry is offline
1952henry is gaining momentum as a positive member of FTE.1952henry is gaining momentum as a positive member of FTE.
I restored two last year. One had the complete pedal to carb linkage. I think I got $30 for just the linkage and $50? for the complete unit with swivel. All pieces were redone and plated. NO paint used. You can see the part number in the longer linkage piece.
Old 01-07-2014, 12:30 PM
51PanelMan's Avatar
The pedal linkage pictured in the first picture is 53+. The carb linkage is similar 52+. The three "fingers" connector has flat "fingers" unlike the slightly bent "finger" as pictured.
Old 01-07-2014, 12:33 PM
1952henry's Avatar
Quote:
Right you are. I got both carb linkage piece from two 54s in a junkyard. The pedal bracket came from a '53 V8 big truck.
Old 01-07-2014, 01:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Well, I'll take a turn at being harsh too. NOS Parts had something I needed that was at best a $10 part and wanted $40 for it, plus (IIRC) $12 to ship it, when it would easily fit in a $5 Flat-Rate box. I got the same part, also NOS, for $20 including shipping elsewhere. Antique Auto is my first choice, I'm sure it was them that couldn't find the part?
Old 01-07-2014, 01:35 PM
alamartina's Avatar
True, Ross. They are still looking for it. Their system says they have one, but still lost. Hopefully they will find it.
Old 01-07-2014, 02:00 PM
1952henry's Avatar
I was just stripping an old glass bowl 1904 Holley and noticed it still had the piece you need attached. Problem is, looks like some previous fellow grabbed it with a pliers. With some re-engineering (a few strokes with a small hammer), I got it to release the ball. If you could use it, it's yours. Not real pretty with the pinch marks.
Old 01-07-2014, 02:04 PM
alamartina's Avatar
Looks aren't everything...
What are you asking for it?
How do I PM you with private email?
  #28
Old 01-07-2014, 02:25 PM
1952henry's Avatar
I was just playing with it and you will have to as well. I don't want a thing for it as it is boogered and may not end up working too well. Email me:
otpete@midco.net
I'll even send you a brand new clip, if I remember. I have a whole box full of these Dorman pieces.
  #29
Old 01-07-2014, 02:44 PM
alamartina's Avatar
I am a true Freshman User! My questions must seem old news to the experienced folks.
From what I can gather PN TRAA-9772-A is 2.1" long. There is a TRAA-9772-C which is 4" long. I measured mine (on the vehicle) and it is 2.5" long. Are they adjustable in length? I'm getting a headache of confusion!
Best and worst purchase of my life - 1978 f150 TheSterling 1973 - 1979 F-100 & Larger F-Series Trucks 16 02-12-2016 11:41 PM
'71 f100 electrical help, dcaudet 1967 - 1972 F-100 & Larger F-Series Trucks 26 03-11-2014 04:35 AM
AOD TP (throttle position) Rod or linkage Leeboy1962 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 02-23-2014 02:48 PM
Throttle linkage retainer clips Nothing Special 1966 - 1977 Early Broncos 13 11-11-2013 09:53 PM
1982 4 speed overdrive manual clutch linkage parts The_Builder 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 06-21-2013 01:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
