92 F150 engine swap? - Ford Truck Enthusiasts Forums
Old 01-05-2014, 06:26 PM
SVLON SVLON is offline
SVLON is starting off with a positive reputation.
I have a 92 F150,302 V8,automatic EOD and EFI.The engine is still running fine but is getting a bit tired.Understandable with 300K miles on it.What years will interchange with little or no changes?Id like to keep the old girl and just swap in a newer engine.
Old 01-05-2014, 07:08 PM
88LX5.0H's Avatar
88LX5.0H 88LX5.0H is offline
88LX5.0H is gaining momentum as a positive member of FTE.
You can put just about any 302 you want in there. I went with a 2000 model Explorer motor in my Bronco.
Old 01-05-2014, 09:46 PM
Did you also have EFI??
Old 01-06-2014, 12:44 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Any year 302/5.0 will bolt in there and you could put all the EFI stuff on an earlier carbed motor if you had to, but the ideal candidate would be a '92+ truck 5.0 to get a roller cam and a '94+ to get the improved roller cam. In all cases you do not want to use any wiring that comes with the donor motor,
Old 01-06-2014, 01:46 AM
Many thanks.That info helps a lot.Greta site and good people.
Old 01-06-2014, 09:16 AM
88LX5.0H's Avatar
Quote:
Wouldn't have it any other way.
'92-'96 instrument clusters Old Primer Red 1987 - 1996 F150 & Larger F-Series Trucks 2 11-04-2014 08:51 PM
WTB: 92-96 F-150 Rear Flareside Step Bumper gentlemansbeard WTB - Parts & other 0 07-15-2014 08:48 PM
tranny swap miniowner92 1987 - 1996 F150 & Larger F-Series Trucks 3 05-12-2014 11:55 PM
F-150 Engine swap dwhalenaz 1987 - 1996 F150 & Larger F-Series Trucks 7 03-29-2014 07:43 PM
92 f-150 with 302 swapping to a carb couple questions *92flareside* 1987 - 1996 F150 & Larger F-Series Trucks 11 04-01-2006 02:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
