Installing the Heidts IFSin the '53
I have been planning on this part of the build for a few months and finally the time has come....
A little progress....
I got the IFS from JPL Street Rods, They were easy to communicate with and all the parts came intact!!!
After I tact the cross member in place I found that it needed to be moved forward 1 1/4". After I remounted it I did the mockup of the fender and now it looks like the tires will be in the center of the fender. Just the way I wanted it...
Here is a picture of where the center line was and now where the center line is...
I have a buddy that is a "certified welder".... Damn he did a GREAT JOB!!!!
After a little paint and a little time Wala,,, Looks good!!
Does this look correct???? The instructions for the Rack and Pinion didn't say what to do with the washers.
And How tight are the "inner tie rod ends" put on and how much can I crank on them before I can do damage to the Rack an Pinion? I checked and found NO pins installed so I should be able to unscrew them but NO dice... HELP!!!
That's what I'm talking about. I just don't want to twist something. I used a 1/8" drill bit and found no studs in the holes. I tried to turn it out to install the 2" extensions and WOW it is TIGHT!!!! I'll take a look at it tomorrow.
I'll let you know what I find on this,,,, But I think I could just cut a new 1/4" pipe the new length to make that work...
Received 4,132 Likes
on
BTW, I came in this morning and put a little more pressure on the wrench and it came loose.. I am good to go!!! Thanks!
on
Also I got the whole setup from JPL Street Rods. Good to work with and it seems all the pieces showed up.
on
That's okay, I haven't started this new project yet.
Like I said, This is going to take time.
