bubba's dizzy conversion - Ford Truck Enthusiasts Forums
Old 01-05-2014, 05:25 PM
r_reed's Avatar
r_reed r_reed is online now
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
after a rebuild and mild upgrade of my EAB, the next weakest point seemed to be the load-o-crap distributor. based on suggestions from FTE and Ford Barn Folks, i purchased a chevy distributor converted for flatheads by Bubba's Hot Rod shop. It took about 15 minutes total to put it in, it started immediately and runs great. won't have it on the road again until spring, but really looks like a nice upgrade. the chevy dizzy is taller than the flat-o-matic, but it is barely noticeable, except maybe to chevy guys. dick r.
Chevy Distributor Conversion for 1949-1953 Flathead Ford
Old 01-05-2014, 05:35 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Nice. I have one as well and am very happy with the performance. I plan on sending mine back to Bubba for a tune up and have him add the vacuum advance for better mpg's.
Old 01-05-2014, 09:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
You won't regret it, Dick!
I have an MSD, same basic setup, and find that vac advance does more than just economize. At part throttle it gives you a much more lively engine. BTW Scott, I think you can add it yourself, just buy Mr Gasket #31034 for GM points style dizzy. I have mine set to a maximum of 8 deg. advance, per results from "Richard in Florida" on the Barn.
Old 01-05-2014, 10:02 PM
tinman52's Avatar
Welder User
Yes, I talked to Jim(Bubba) about it......he said he would do it for minimal cost and check out the dist at the same time. That way I can't screw it up....
Old 01-05-2014, 10:17 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
OMG!!! A chevy in a Ford????? How can you do that, I just can't believe it...
Hmmm, I guess it is ok if a purist does it because, well...
I have gotten a lot of grief for having a SBC in my truck, just sayin.
Old 01-05-2014, 10:32 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
He can also do a Mallory dizzy if he has one on hand.
Old 01-05-2014, 10:55 PM
r_reed's Avatar
my good friend has a camaro, corvette and a 32 chevy coupe: of course he has a 9" Ford rear end in the coupe, so he understands. i'm certainly not a purist, but i did rebuild the flathead to keep that part of the heritage alive.
Old 01-05-2014, 11:14 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Everyone I've known with a Mallory in any engine has constant problems with them. Especially dual-points.
Old 01-07-2014, 08:34 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
The only reliable dyno testing I have seen of a stock 8BA found that the original carb and distributor setup gave the optimal timing curve for power. This is documented in John Lawson's book Flathead Facts which is an excellent book for anyone interested in flatheads. If a longer duration cam is used or a not stock carburetor is used then you need a different distributor.
Automatic Tranmission 1950FordF1 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 04-22-2016 10:33 PM
Correct Distributor Setup 1951 Flathead V8 hulleywoodworking 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-31-2016 09:12 PM
"way we were" car show and a special flatmotor r_reed 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 10-14-2015 11:01 PM
Engine swap Bubba-88 Performance & General Engine Building 13 11-29-2014 09:42 AM
Help with TDC Flathead 6 Flathead ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 09-18-2013 03:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
