2001 Screw 4WD not engaging
I was out on the lake last night and after getting stuck in 6" of hard packed snow, I discovered that my 4WD is not engaging.
When engaging 4WD, I do hear 2 clicks several seconds apart. I've checked the lines from the solenoids to the actuator and did not find any cracks. I have not checked the lines for vacuum yet but...
Last winter while engaging 4WD, I heard a load POP from the front end when I was turning the wheel and engaging 4WD. Ever since then, I haven't been sure if its been engaging but it was confirmed yesterday on the lake.
Based on what I've read, I assume its either the actuator or the shift fork. Is it possible to remove the actuator and test it without disassembling the entire front end?
EDIT: I went under the truck and had my wife engage and disengage the 4WD. The actuator was trying to move (maybe 1/16" inch) but the shift fork wasn't moving. Does this mean the shift fork is bad (frozen) or does this mean the actuator is bad (not enough power to move the fork)?
I hosed everything down with penetrating oil and moved things around. I tried removing the actuator but couldn't, even after removing the c-clip. I am getting about 1" of movement now which is marginally better.
How much movement should there be at the actuator and if 1" is normal, does that mean I have a bad shift fork?
