6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
refilling cooling system
Old 01-05-2014, 09:23 AM
regenhater's Avatar
regenhater
regenhater is offline
I just finished changing the thermostats and block heater on my 2010 6.4 super duty. does anybody have the procedure for filling the cooling system. I'm filling it through the degas bottle but its not going to fill anything above the lowest point. I have seen a pressure tool for this but $200.00 is a little steep for a tool I will only use once in while.
Enjoy the snow.
Old 01-05-2014, 09:40 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
I didn't have the vacuum filler when I did mine and just filled it the old fashion way, just check it regularly the first week to top off if needed. I let mine idle until the stat's opened, (which took what seemed like forever) topped off and haven't had to add any since.
Old 01-05-2014, 10:24 AM
regenhater's Avatar
regenhater
thought that's what I would have to do. Was hoping for a point a wand at it and it would it be done type of method. Old school it is. Thanks.
Old 01-05-2014, 06:52 PM
wp6529's Avatar
wp6529
wp6529 is offline
You might see if one of the "Air Lift" type fill tools is available under the tool loan program at your local auto parts places. I believe you will have a difficult time getting all the air pockets purged without one, and in an engine known for cavitation issues, I wouldn't want to do anything that could cause pressure building and cavitation issues.
Old 01-05-2014, 09:36 PM
Planner22's Avatar
Planner22
Planner22 is offline
I just bought one on Amazon for 75 bucks. Its a must on the 6.4's.
Old 01-06-2014, 11:49 AM
regenhater's Avatar
regenhater
I will be researching that tonite. I saw a couple of them on ebay ranging from 60. to 250. Thanks for the help. -15 or -40 with wind chill. Love winter.(?)
Old 01-06-2014, 07:11 PM
PSDx3's Avatar
PSDx3
PSDx3 is offline
Very important to refill coolant using vacuum with the prescribed procedure. Air can stay in the system for a long time resulting in cavitation, and steam which creates hot spots and extreme pressure spots.
Old 01-14-2014, 11:50 AM
regenhater's Avatar
regenhater
Thanks for the help and suggestions. Got it all done.
Old 01-15-2014, 07:42 PM
longview1's Avatar
longview1
longview1 is offline
Guess im screwed then as Ive never used a vacuum system to refill coolant...
Afireinside2285
Aerostar
24
04-22-2009 02:10 PM
TheHandyman
Aerostar
09-07-2007 07:53 PM
Lakeitel
06-19-2003 09:47 AM
Roadhog123
06-17-2003 12:18 AM
Quick Reply: refilling cooling system
