Do engine block heaters run constantly or start & stop?
I have a frost plug type engine block heater. Once it is plugged into the wall outlet, I'm wondering if it runs constantly? Or does it get the coolant up to a certain temp, then shut off for a while and re-start when the coolant temp drops?
All block heaters are on once plugged in unless there is a control unit between the plug and heater element.
I have my extension cord plugged into a timer that comes on 3 hours before I have to leave for work. It also shuts off 3 hours after I leave just in case I have to leave later or for my days off.
Another forum member did a test and logged data on how the factory block heater works once plugged in. IIRC the factory block heats up to 125 in the first hour and then drops off to around 90 there after.
on
Sent from my Galaxy Note 3 using IB AutoGroup
Plugging it in and leaving it doesn't hurt. My work truck is plugged in 24/7 when it's cold out because we never know when we need it.
In weather like we are having right now (-20*F) I plug my Ex in when I get home, Nd unplug it when I leave for work. It even stays plugged in when it's warming up in the morning. Usually 15 min or so when it's this cold.
As for the original question, on the excursions, plug it in and it's on.
Quite something one need not worry about I wouldn't think
Only when you get the electric bill! I use a timer on both my work van/excursion.
Never heard of that before.
It's just a heating element, running the vehicle shouldn't hurt it even with it plugged in. It can't reach any temps higher than it sees any other time.
Infact, when you first start the engine, it will start moving the warm coolant out of the block and replace it with cold stuff from the radiator. So theoretically, leaving it plugged in during warmup would help it warm up faster.
