Need help with 48 f2 inner and outer fenders
Prepping my inner and outer fenders I realized I totally forgot how they go back together and may not have all the parts It's been 15 years since I tore it all down, just knowing it would all be put back together within months. I did a search and didn't find what I wanted I'm looking for pictures and text on how it all ties together. Sure can use some help Dennis
I bolted the inner fenders on first. They bolt to the firewall (top/rear) and to a stud on the frame (bracket bottom rear). The front bolts through the radiator saddle/mount with the braces mounted to the same bolts.
The outers bolt to the top of the inner fenders, and then the other front sheet metal goes on (upper and lower center pieces, lower fenders, grill). They will be rather "floppy" until you get them bolted to the running boards.
It is a good idea to leave everything loose until they are all tied together for final fit. Not great pics but you can see the inners mounted, then the outer
I guess that I don't understand how you fit the fenders to the hood. The hood has more adjustment built into it. Once the hood is in final paint, I plan to fit it to the inner fenders and grill/front sheet metal without the front fenders installed. The primary reason is ease of handling the hood during assembly. You do not have to lean over the front fenders.
On the 1948-1952 trucks this doesn't seem to be that big of a problem. Our hoods are generally strong enough to maintain their shape and fit the cowl properly. I'd still set the hood on first to check fit. If all looks good, put the front sheet metal together in the order that works best for the space you have.
(Says it's closed but I still have some stuff, including the inners and grille parts)
BTW the biggest argument for assembling the front end before setting as a unit is the sheer number of bolts in the grille area, and they are a PITA to get to once they are on the truck. But if you do it that way, you still have to leave them loose so you can tweak things.
It's been a while since I've installed the front end on my '49 F-2 but I started with the radiator bracket, with the radiator, then the inner fenders, the grill and then the fenders, tops then bottoms, leaving all the bolt loose.
I also edge painted the fenders, leaving the overall fender sheet metal in primer. I did have the radiator, inner fender panels and grill painted before I installed them. I left the fenders in primer because it's easier to fix nicks and scratches in comparably cheap primer than in expensive urethane paint. I do this with all body panel I have to hand on a vehicle. I then tape off the parts in sections and painted them after they were bolted on. I hate handling painted parts any more than I have to. It does help that I do all my own paint work.
Here are some pictures from the part catalog.
GreatNorthWoods
07-24-2006 02:45 PM
