charging system flicker...
Okay so I figured I would go through the charging system on my truck.. I ohm tested my ground cables and positive cable and found little resistance. The voltage regulator has been replaced with new, a new Motorcraft alternator as well. Both batteries are new within one year and load test good. The issue I'm having is the headlights and interior lights flicker with no load, as soon as I turn the heater on hi the lights do not Flicker anymore.. I know I should be doing a one wire alternator or a 3G set up, but I got a smokin deal on this alternator that was on the shelf. I cleaned all the grounds that attach to the fender well / body area, all the battery terminals are clean as well. I ran a small gauge wire from the alternator bracket to the ground side of the battery and has no effect, lighting still flickers. Is it possible a bad voltage regulator?
Yes when I started going through the wiring I also found a lot of corroded ends and some wires only had a few strands.. I'm going to clean the interior grounds tonight, but as far as lighting I have no more flicker.. after I replaced the regulator & alternator I was changing around 15 volts, not so good... when I added new/clean grounds as well as a new 4ga charge wire it dropped back down to 14-14.5 where it should be
jdwxly
13
09-23-2019 09:52 PM
bob_351
11-16-2007 06:18 PM
