Shortbed, no gooseneck trlrs???
The proper location (center of gravity) for both gooseneck hitch or 5th wheel hitch is min. 2" in front of rear axle . Locating it behind the rear axle causes unstable driving (lifts front axle of the truck) , locating right on the rear axle does not distribute enough weight to front axle .
Some short-box owners get by , by using a slider-hitch in combination with an extended king-pin box .
You can do one exercise for yourself . Assume that you have a wide-body trailer which is 8.5 ft wide (5th wheel trailer , travel trailer or horse trailer or work trailer ) . Divide that width in half and swing a stick or tape measure from your "imaginary goose-neck ball location(2" in. in front of rear axle) . See how much clearance you have for a 90-degree jackknifing, if any .
Good luck,
Good luck,
Everything I tow is bumper pull so I haven't had to try out the gooseneck ball yet...
I'm not sure that you're being clear enough to have everyone on the same page here.
I'm gathering that you have a shortbed 11 up truck with the factory 5th/ gooseneck prep package, and you want to connect to a gooseneck trailer. Is that the case?
If so buy the ball and chain hooks and go for it. I think that Ford was only offering the prep package with the longbed trucks early on, and what you found may be old info.
That said, with a gooseneck and short bed you do need to keep cab clearance in the back of your head at all times, because you don't have the jackknifing ability you do with a longbed. Depending on the trailer coupler, you may be able to get an offset insert to gain a little bit of clearance.
My 2000 F250 shortbed has an aftermarket goose neck setup that was put in by the previous owner. Most goose neck trailers should have good clearance without hitting the cab depending on the style of trailer. I have a family member that pulls a fifth wheel with his 06 shortbed just fine but he does have to watch the tight turns.
F350FordToy
Fifth Wheel & Gooseneck RV Towing
24
01-03-2018 12:17 PM
RoyalFord
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-15-2004 02:44 PM
RedTaurus94
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
07-18-2004 09:36 AM
