Engine mounts question
I believe the F-150 4x4 and F-250 4x4 use different frame stands. Pretty sure you will need stands for a F-150 4x4 with a 302. I don't know if the 302 and 351/400 used the same stands.
Perhaps ND will see this and supply you with the proper part numbers / interchange.
Good luck.
Roger Carter
Good luck.
Roger Carter
302 and 351/400 stands will interchange between F-150 2wd and F-250 2wd.
I know 2wd and 4wd stands are different when dealing with F-250's. Not 100% sure about the F-150 4wd.
Did your research differ between 2wd and 4wd? F-150 and F-250?
Maybe we can't believe everything we read on the internet!
RC
RC
I have been researching this same thing From the Master Parts catalog. It appears that you can use the same mounts just adjust where they bolt to the frame(4WD) or cross member(2WD). For 300 use forward most holes and rearward for 302,351 and 400. Here are the two pages and a pic of my 2WD setup for the 300.
Have you checked the text portion of the catalog? The illustrations are "typical" and show the basic numbers for the parts, 6028 right and 6029 left.
Not trying to knock your research, that is what it will take to answer the OP's question. Just want to be sure all the research is done.
RC
1980 and later parts do not interchange with 1979 and older.
2WD same engine supports (6028/6029) aka towers/stands/perches: 1969/79 F100 302, 1975/79 F150 302, 1977/79 F100/350 351M/400.
Parts catalog pics of 6028/6029 applications: Left (upper) & Right: 240/300 I-6 / Left (lower): 351M/400.
53deere
08-11-2018 04:30 PM
Erock1973
16
05-23-2017 12:59 AM
gossman
07-31-2001 05:56 AM
