Trailer brake/turn output not working?
So I'm in the middle of a trip with a 20' trailer and my lemon of a truck has decided my trailer doesn't need brake or turn signals.
Before someone says its the trailer, its not. With engine running my fluke shows no voltage at the proper pins on the 4 or 7 pin plugs. Running lights and trailer brakes work fine too.
Relays and fuses test fine. I don't want to take the time to run this POS to the dealer. Anyone seen something like this before?
mostly bad connection
when I bought this truck (used) in August, neither the trailer lights nor signals worked. both fuses were blown
Both signal lights should be powered by Fuse (F100). The brake is Pin 2; the TBC won’t apply voltage to that wire if it doesn’t sense a trailer is connected to it. Nor should the TBC give an output if the truck is not moving, I believe over 5 MPH. <o></o>
I don’t know if you were checking the right fuses for the trailer signal lights. And as far as the TBC, how do you know the brakes were not working? Did try moving the manual override lever when the trailer was hooked up?
Just guessing, I dont have the information with me. But pin 7 should be for the reverse lights? Pin 4 should be for the trailer battery charge.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Both signal lights should be powered by Fuse (F100). The brake is Pin 2; the TBC wont apply voltage to that wire if it doesnt sense a trailer is connected to it. Nor should the TBC give an output if the truck is not moving, I believe over 5 MPH. <o></o>
I dont know if you were checking the right fuses for the trailer signal lights. And as far as the TBC, how do you know the brakes were not working? Did try moving the manual override lever when the trailer was hooked up?
Glockem45
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
41
11-12-2010 05:56 PM
Choke
1997-2006 Expedition & Navigator
07-14-2004 04:14 PM
