DP Infinity help, (installing EGT and other ?'s) - Ford Truck Enthusiasts Forums
Old 01-04-2014, 11:22 AM
Diesel 724's Avatar
Diesel 724 Diesel 724 is offline
Diesel 724 is gaining momentum as a positive member of FTE.
Just received my DP Infinity in the mail. Its pretty sweet, I'm learning the basics of it. I'm a little bit confused at all the parameters i can monitor, some work in my truck, some don't, and some are irrelevant.
I have an EGT probe im looking to install, a single probe not dual. I was wondering wheres the best place to put it and how about doing so, just drilling and tapping?
Also, Im looking to monitor BOOST, what would that be? Ive read around and i think that MGP is what im looking for? Thats the straight boost number? Because if i monitor MAP psi i have to subtract numbers? A little bit confused. (confused a lot with all these abbreviations and such not knowing whats what)
And I also read my codes, one for sure I have is P0272: cylinder 4 contribution/balance it said. I also have some other codes i didn't write down but im thinking they are from having from Air intake heater removed, and waste gate actuator unplugged. I can go check them later and post them just for conformation later.
Old 01-04-2014, 11:26 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Did you clear your old stale codes and get a fresh reading?
You can see my pyro sensor behind the orange connector in this photo - it's on the manifold before connecting to the up pipe.
MGP - Manifold Gauge Pressure. That's the boost PID... good call.
Old 01-04-2014, 11:35 AM
Diesel 724's Avatar
Thanks. Yes i have cleared my codes, and also ran acouple tests that come on the Infinity. It all came back about that cyl 4, except the buzz test came back good. So maybe today i will clear my codes again and drive for alittle then test it again before i come inside.
As far as EGT ok, thats where i was thinking it went, im not looking right now at my truck but is it a hard location to access? Am i looking at a PITA job here or fairly simple, because the weathers cold out and i dont have garage access so i might wait alittle to attemp this.
and MGP thats the straight correct number for boost, with out adding or subtracting anything?
Old 01-04-2014, 11:54 AM
Tugly's Avatar
You want to record your PERDELs for all 8 cylinders with the Engine Oil Temperature above 150 degrees F (65 C) and your cabin heat "Off", then you'll know what's up with the code.
"Absolute" (MAP) pressure is the raw reading from the sensor.
"Gauge" (MGP) pressure is the reading, minus the atmospheric pressure from the BARO sensor. In other words, the math is already done with that one.
That location on the manifold is easy-access - that's why so many people put the EGT sensor there. Avoid putting it too far to the right (as seen from the photo). My sensor position permits removal of the cooler without having to dink with the sensor or the wire.
Old 01-04-2014, 12:02 PM
t.scottNDU's Avatar
t.scottNDU t.scottNDU is offline
t.scottNDU has a good reputation on FTE.t.scottNDU has a good reputation on FTE.t.scottNDU has a good reputation on FTE.
I just got my Infinity in the mail yesterday and I love it so far. I haven't done much other then gauges and check DTC's. I'm really looking forward to a buzz test and CCT. Glad you like it as well!
Old 01-04-2014, 01:30 PM
Diesel 724's Avatar
I went out and set my truck to MGP and it just dosent seem right to be my boost gauge. Its numbers and parameters are way to low and high..
Old 01-04-2014, 01:40 PM
Tugly's Avatar
Watch out for decimals. You might be going from -3 to 170... but it's really -0.3 PSI to 17 PSI. I confirmed with data I have here - MGP is the one.
Old 01-04-2014, 02:01 PM
Diesel 724's Avatar
This is what options i have:
This is what i get when i pick MGP
Old 01-04-2014, 07:20 PM
Diesel 724's Avatar
I have played with it more. MGP reads 12 at an idle and hits upto 50.
Old 01-04-2014, 10:40 PM
Tugly's Avatar
Basing at 12, and going up to a reading of 38 above base? That acts more like a Exhaust Back Pressure sensor in Denver. I've seen Infinity multiply things by 10 before, I wonder if it's showing 1.2 PSI to 5.0 PSI. That would be normal in the driveway (powerbraking), but not on the highway.
Old 01-06-2014, 06:37 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner Justin@DP-Tuner is offline
PREMIUM SPONSOR
Justin@DP-Tuner has a good reputation on FTE.Justin@DP-Tuner has a good reputation on FTE.Justin@DP-Tuner has a good reputation on FTE.
Yes, MGP is the actual boost number, as Rich has described.
You can set the low and high values. Just touch the Low Limit box and change the value to 0, then touch the High Limit box and set it to 35.
This sounds like there may be an issue with the MAP sensor if you are seeing these values for MGP, especially since the factory MAP sensor only reads up to 35psi of boost.
__________________
Like us on Facebook!
www.dp-tuner.com
Old 01-21-2014, 01:51 PM
cjgray1974 cjgray1974 is offline
cjgray1974 is gaining momentum as a positive member of FTE.
My mgp reads 0 to 1 at idle. Another thing to chech would be the MAP, EBP, and I think the third is AP, Atmospheric pressure. they should be within about .5 of each other. If the MAP or AP is off it could be throwing off the calculation for MGP.
Old 01-21-2014, 02:07 PM
Just ansd looked at my infinity. It's map, baro, and ebp.
map - manifold absolute pressure
baro - barometric pressure
ebp - exhaust back pressure
mine are right around 12.4 at around 1000ft elevation. You want to check it with the engine cold.
my EBP was reading 24 so I need to figure that out when it warms up. probably explains why I thought my milage sucked last week
Turbo Cool Down (Timer vs. EGT) ghott 6.0L Power Stroke Diesel 4 01-28-2016 03:39 AM
Powermax Turbo issue, need advice! Kobra62 6.0L Power Stroke Diesel 15 01-31-2014 08:01 PM
To buy or not to buy the DP Infinity. flavo 1999 - 2003 7.3L Power Stroke Diesel 22 06-07-2013 02:14 PM
ScanGauge II: what else to monitor? DieselVol 1999 to 2016 Super Duty 1 07-21-2012 04:37 PM
BSFC and Exhaust Gas Temps (EGT) Info MaxRaceSoftware Performance & General Engine Building 1 06-28-2002 12:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
