IS THE 6.2 A BIG BLOCK ? - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 01-04-2014, 06:48 AM
winginit's Avatar
winginit winginit is offline
winginit is starting off with a positive reputation.
What size is the motor,and hp ratings? Will
Old 01-04-2014, 07:14 AM
Slowpoke Slim's Avatar
Slowpoke Slim Slowpoke Slim is offline
Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.
I don't think it's a "Big block" per se.
Hp is 385, torque is 405.
Old 01-04-2014, 07:18 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
I think it is considered a medium block and was designed with 7 liter displacement in mind. There are some running in drag racing.
Old 01-04-2014, 07:31 AM
winginit's Avatar
Quote:
That`s what i thought. thank`s Will.
Old 01-04-2014, 11:03 AM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
The 6.2 is a 379 cubic inch with a 4.01 bore with a 3.74 stroke motor. I grew up in the muscle car days and back then we considered the 289, 302, 289, 327, 340, 351W to name a few small blocks. When you got into the big bore motors like the 351C, 390, 427, 383, 440, 348, 396, 454 then they where big blocks, many of the big blocks shared the same block but longer strokes to make bigger displacement. So back then you would open up the hood and see a small motor like a 289 and it was small compared to a 351C so it was a small block.
I consider the 6.2 a big bore short stroke motor and when you get on it that's what it sounds like and it looks big under the hood.
Denny
Old 01-04-2014, 11:45 PM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.
The Bore Spacing is typically the determining factor.
Ford traditionally had three different bore spacings for their V8 engines:
4.38" was a "Small Block"
4.63" was a "Medium Block"
4.90" was a "Big Block"
That was further broken up into tall deck and short deck blocks. For example, Ford's old 302 and 351 (Windsor or Cleveland) both had a 4.38" bore spacing, but the former was a short deck block, while the latter was a tall deck block. Taller deck meant a longer possible stroke, which meant greater displacement without moving to the next bore spacing.
When they introduced the Modular Engine Family, the main characteristic of that family was a 100mm bore spacing. The 4.6L has it, the 5.0L coyote has it, the 5.4L has it, even the 6.8L V10 has it. In English measurements this would be a 3.937" bore spacing, making it essentially a smaller than small block using the old naming system.
Of course the problem you run into with the Modular family is that your bore spacing limits your displacement. Even with a tall deck block you're still limited to about 5.8L in a production Modular V8 engine. Hence why they had to create the 6.8L V10....it's essentially a 5.4L V8 with two more cylinders added.
Since everyone else was moving to 6+ liter V8's in various applications, Ford felt they needed a new engine design to be competitive. That required a different bore spacing, which then requires a completely new engine family. Hence why the 6.2L is from the "Boss" family and not from the "Modular" family, even though they share a lot in common.
Now the Boss engine family uses a 115mm bore spacing, which would be 4.53".
Here is the bore spacing on some other engines:
Chevy Small block (both traditional and modern LS family): 4.40"
Chevy Big Block: 4.84"
Chrysler/Dodge A and LA Small Block: 4.46"
Chrysler/Dodge B and RB Big Block: 4.80"
Modern Hemi Small Block: 4.46"
So where does the Boss engine family fit in? At a 4.53" bore spacing it's not a big block in the traditional sense. It's not really a small block either. It's closest to a medium block, though like the Modular family, it doesn't quite match the bore spacing of Ford's old medium block.
I guess, with all the true big blocks gone from regular production, we could say the 6.2L is a modern big block, but I feel like that would be confusing and just a little too inaccurate.
Maybe if Ford brought out a production version of the Boss engine with more than 428 cubic inches I could be swayed. That's about where the old medium block family stopped and GM's new small block stops at 427ci for a production engine. I think a new Boss with about 460ci would be just perfect. They could use it in the F650 and maybe a limited edition F250.
Old 01-04-2014, 11:51 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
your numbers are correct in a super duty, but in a f-150 they are 411HP and 430TQ
Old 01-08-2014, 07:25 PM
BlueOvalJunkie11 BlueOvalJunkie11 is offline
BlueOvalJunkie11 is starting off with a positive reputation.
doesnt the 150 have a hotter cam for those numbers? or is the super duty 6.2 just detuned?
Old 01-09-2014, 06:29 AM
They are actually closer than a glance would indicate. The F150 is rated on premium fuel where the SD is rated on 87 octane. The Ford engineer stated way back the SD was very close to 400 hp on premium fuel. Not sure what they did though to make that extra 11 or so hp.
Old 01-18-2014, 12:08 AM
SDDL-UP SDDL-UP is offline
SDDL-UP is starting off with a positive reputation.
+1 03 SVT VERT
In no way is a 351C a "big block"! Even the 351M and 400 are just tall deck small blocks.
I would agree with your assessment of the 6.2L Boss as well. It's a small block with a lot of displacement potential.
Old 01-18-2014, 08:20 AM
FordmanNJ's Avatar
FordmanNJ FordmanNJ is offline
FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.
Is the 6.2L V8 a big block?
Yes. It is the biggest block I have owned! LOL Before the current truck, my F150 had a 5.4 which was .4 liters more than any other V8 I owned. Ford 302 and Chevy 305. Everything else was a V6. If I were to purchase an inline 4, I would not know what to think of it. I would probably say where is the other half of the engine! LOL
Old 01-20-2014, 11:54 PM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.Louisville Joe is gaining momentum as a positive member of FTE.
6.2L a 'big block'? Sure, about as big as you are going to see these days. As for the Cleveland/M/400's, SDDL-UP is right, they are small blocks. Bore spacing is the same as a Windsor.
I think the 'Boss' bore spacing as about the same as the old FE's.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
delete 97puller Ford Truck Parts for Sale 15 04-08-2014 04:53 PM
test jr105 Testing..... 0 04-04-2014 08:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
