Brake lite switch mounting on swinging peddle assm. - Ford Truck Enthusiasts Forums
Old 01-03-2014, 11:23 PM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
I have mounted a swinging peddle assm. in my 52 F-1 and cannot find fittings to mount a pressure brake switch on the master cylinder.
I have two 3/16" line ports to feed the front wheels but I only plan to use one and "T" off to go to the other side on the front.
another port feeds the rear brakes.
To get a pressure switch on the cylinder I would have to have an adaptor to go in one of the front 3/16" inverted flare ports and adapt to a pressure switch.
Unless someone can come up with a better idea I am going to mount a switch under the dash on the brake peddle.
TractormanBill
Old 01-03-2014, 11:55 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
Put a "T" in the line to the rear and place your switch in it. That is how I have ran mine for years.
Old 01-04-2014, 01:40 AM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
I would say go with a GM style switch on the brake pedal, just make a small bracket and that's it.
If your really set on a hyd pressure switch then look for a trailer tee.
Old 01-04-2014, 07:50 AM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
Either of the above ideas will work fine. You can also run a brake line from the open fitting you show to a flare to pipe thread adapter and install the pressure switch there. Otherwise be sure and cap the open port before you begin to bleed of your going to have a mess.
Old 01-04-2014, 08:01 AM
ohbrian ohbrian is offline
ohbrian is starting off with a positive reputation.
Unless you already have the parts handy, midfifty sells a kit to do what you need.
Old 01-04-2014, 08:13 AM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
I like the gm style switch better than the inline hydraulic switch. I found you had to apply a great deal of pressure on the pedal to make the lights come on where the gm style the lights come on instantly which I think would be handy in heavier traffic. The last thing I want is someone piling into the back of me because he/she didn't see my brake lights. Brakes are important and so is a warning for anyone following you.
Old 01-04-2014, 10:28 AM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
Switch on the pedal for me. One of the early GM switches with the arm that rests on the pedal.
Old 01-04-2014, 10:35 AM
tractorman
Thanks for all the suggestions and I already have a GM switch so I will just make a bracket and mount on the peddle assm.
TractormanBill
Old 01-04-2014, 04:09 PM
mytbtruck's Avatar
mytbtruck mytbtruck is offline
mytbtruck is starting off with a positive reputation.
Any time you can use an electrical switch instead of a hydraulic one you are way ahead of the game. If you ever install a cruise control you cannot use the hydraulic switch. The GM swich is as good as any. I used the original switch on my pedal from the T-bird. As soon as you touch the pedal the lights come on and the cruise disengages.
Old 01-05-2014, 12:10 AM
tractorman
I am convinced, go electrical and help clean up the engine compartment.
TractormanBill
Old 01-05-2014, 09:07 AM
Could someone post a pic of how the electric switch mounts? Now I think I want to go this route too. I have a stock pedal so I'm not sure how this thing works...
Old 01-05-2014, 09:18 AM
Posting Legend
If you don't have a bracket to hold the switch you can make one fairly easy. Position the switch against the pedal arm so that as soon as you start pushing the pedal it opens the switch.
Old 01-05-2014, 10:22 AM
Rimrock F1's Avatar
Quote:
Position the switch against the pedal arm so that as soon as you start pushing the pedal it closes the switch.
John I fixed it for you
Old 01-05-2014, 10:34 AM
Posting Legend
Thanks
Old 01-05-2014, 03:41 PM
tractorman
THere is a $6+ switch at Advanced Auto Parts or nearly any other auto parts store for an 1980 Camaro.
It has two nuts where you can adjust it in the bracket to where the brake arm pushes the button in a little when you are not on the peddle.
The switch is not connecting the terminals when the plunger is pushed in a little and the lights will be off. As soon as the peddle moves away from the plunger the terminals will connect turning on the brake lights.
As you push the peddle in and take up the free play in the master cylinder stroke it should turn the lights on.
I have a question on free play on my swinging peddle assm.
Should I put a light spring on the brake arm to keep free play and not let the peddle rest against the master cylinder push rod?
TractormanBill
Bleeding pbsdaddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-22-2017 02:42 PM
3rd brake light possibilities tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 12-22-2015 01:56 PM
Misc.for 48 f-3 Oakroadjoe Ford Truck Parts for Sale 0 02-11-2015 04:54 PM
Aftermarket proportioning valve ronspolv 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-05-2015 11:32 PM
no clutch pressure any ideas ? hunter444 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-22-2014 07:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
