Brake lite switch mounting on swinging peddle assm. - Page 2 - Ford Truck Enthusiasts Forums
Old 01-06-2014, 07:23 PM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Quote:
Originally Posted by tractormanbill View Post
THere is a $6+ switch at Advanced Auto Parts or nearly any other auto parts store for an 1980 Camaro.
It has two nuts where you can adjust it in the bracket to where the brake arm pushes the button in a little when you are not on the peddle.
The switch is not connecting the terminals when the plunger is pushed in a little and the lights will be off. As soon as the peddle moves away from the plunger the terminals will connect turning on the brake lights.
As you push the peddle in and take up the free play in the master cylinder stroke it should turn the lights on.
I have a question on free play on my swinging peddle assm.
Should I put a light spring on the brake arm to keep free play and not let the peddle rest against the master cylinder push rod?
TractormanBill
GM used a light spring on manual brake cars only to keep the brake pedal retracted up against the switch. Power brake cars have enough return pressure from the booster diaphragm that the spring is not needed.
I adjust the brake switch so the plunger is pushed all the way in with the brakes off, stepping on the pedal lets the plunger out and the switch contacts close.
Old 01-06-2014, 10:42 PM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
I am finishing my brake lines now, need to get the brakes operational and then I will mount the brake switch.
Should the master cylinder push rod have some free play on a power brake system like a manual system has?
Thanks,
TractormanBill
Old 01-06-2014, 11:04 PM
drptop70ss's Avatar
With power brakes I mount the booster and where ever the pushrod is at rest is where I put the pedal. Pushrod length can be extended or cut down but on my GM units the pushrod does not come out of the booster (I am talking pushrod attached to the pedal). Dont pull the pushrod out further from the booster, the free play will be built into the booster.
Old 01-06-2014, 11:36 PM
tractorman
Thanks I'll give it a try.
TractormanBill
Bleeding pbsdaddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-22-2017 03:42 PM
3rd brake light possibilities tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 12-22-2015 02:56 PM
Misc.for 48 f-3 Oakroadjoe Ford Truck Parts for Sale 0 02-11-2015 05:54 PM
Aftermarket proportioning valve ronspolv 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-06-2015 12:32 AM
no clutch pressure any ideas ? hunter444 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-22-2014 08:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
