Speedway disc brake swap - replace outer race (bearing cup)?
Good evening everyone! I am in the middle of installing the disc brakes on my '56 f100. I have the speedway 5 x 5 1/2 deluxe kit (all components together). I got the bearing adapters on easily using the oven technique. The instructions say to replace the outer race and put in the new one that they include in the kit. I just wanted to see if everyone did that and make sure it's necessary, (that the rotors in the kit don't already have the "new" races).
Here is the bearing in the current race.
Here is the bearing in the "new" race.
The difference is minimal...but necessary right? I guess I was just trying/hoping to be lazy...
Boy, it's hard to say from the pictures.... I thought it was clear-cut but maybe not. Can you take pics of the cone and the loose race away from the hub? It does look a little high. Bottom line, it needs to work on the spindle, can you assemble the hub onto the rotor (dry) and see how it stacks?
I agree...I'll try a dry run tomorrow.
Thanks!
Thanks again.
Thanks for the help guys. I guess my main question was/is (and it's probably a stupid one) does a matched set have the bearing raised up out of the race a little bit? I just don't have the experience to know if the one in the rotor was already switched out since they are so close, I just a thought it would be more obvious. But I agree, probably best to follow the directions!
Thanks again.
Thanks again.
The old race - while the bearing "fit" in it..it went too far and so 1/4 inch or so of the bearing was hanging out of the bottom. With the new and correct race, the whole surface of the bearing was in the race.
Now I know!
Thanks everyone, I got it all together and on. I better savor the fresh looking rotors before they rust (I'm working in a driveway)!
Thanks again.
Thanks again.
I hate to bring this back up again... WHY do you have to run the new outer cone?
Of course I assembled the kit without doing the swap.... and I am wondering if it is truly worth doing? Are the angles different? OR is it just so the bearing is not flush with the race? What is the purpose of not having the full surface make contact? (Or is just the top of the bearing touching the surface, thus the deep stance?...
Anyways... Thanks in advance!
I'm not going to answer each question separately , you must use the race that is matched to the bearing for obvious reasons. The bearings are matched to the race. You will get away with the route you chose but the bearing will be short lived. If you don't change to the matched inner race I would suggest you join AAA you'll need them at the most in opportune time. Be prepared to replace your spindle also due to bearing failure.
