fluid leaking dont know what it is really
my 95 f250 4x4 powerstroke ...it was like 29degrees this morning and I when to move my truck so my mom could back out and when I got out I noticed small puddle then it when back all the way towards my truck drips of it lead to it then a big puddle ....its oozing fluid on the driver side under the power steering pump and I don't know if its motor oil ,trany fluid, or power steering fluid...... its dark but it didn t have a smell really I checked my power steering level and it was down a lot and that's what im thinking it is but im not sure...any ideas?????
P/S will turn brown (black in extreme cases) with age along with trans fluid. I'd suggest getting some engine de-greaser and spraying down the pump, lines, and steering box. Use hot water (DIY car wash is good for this, just don't get caught) to rinse it off. Just don't blast the ever loving crap out of it at full pressure. Then get some UV dye from NAPA (comes in small brown bottles) and add it to the P/S reservoir. Get one of those neat little UV lights and yellow tinted glasses as well. Wait a day or so (depending on the severity of the leak and how often you drive it) and then use the UV light to begin searching. The dye will appear radioactive green and should help you pinpoint the leak. Good luck!
1992FordF150Custom
07-06-2014 03:31 PM
bearpa
1999 to 2016 Super Duty
05-26-2011 02:50 PM
