What's up with this turbo mount? - Ford Truck Enthusiasts Forums
Old 01-03-2014, 09:19 PM
donf610 donf610 is offline
donf610 is starting off with a positive reputation.
My turbo has only 2- 10mm bolts and 1 17mm front drive side, also a 2 piece pedestal. The turbo bolt kit comes with 3 -10mm but that is way short for the one where the 17mm is, it's like 1" longer to go through where the 2 piece pedestals over lap, than into housing. The turbo was replaced in 07 under warranty, possible upgrade
truck is a 2004.5
Old 01-03-2014, 09:47 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
never heard of a 2 piece pedistall
Old 01-03-2014, 09:51 PM
Fal-308-Win's Avatar
Fal-308-Win Fal-308-Win is offline
Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.
Is is an After Market Turbo??
Old 01-03-2014, 09:52 PM
Quote:
wow, so this a unique pedestal, I looked every where and can find none like it. doesn't make sense
Old 01-03-2014, 10:04 PM
Quote:
no, it's a Ford re manufactured 2007
Old 01-03-2014, 11:01 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Can you post a picture?
Old 01-04-2014, 12:09 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Sounds like the Turbonetics 6.0 mount
Josh
Old 01-04-2014, 06:30 AM
I can tell you there are 2 STUDS coming up out of the valley of engine for the smaller of the 2 pieces, which even seems more like an oem pedestal. Total of 6 fasteners
I will get a pic when I remove for oil cooler replacement. I just swapped out failed egr cooler to flush system so I wouldn't clog new OC.
Old 01-04-2014, 07:05 AM
Heres a pic of front lower driver side of 17mm bolt. behind shoulder of bolt is the small piece of pedestal that goes down to valley on 2 studs near hpop, the one behind that goes over to passenger side of turbo for the other 10mm bolt.
Hope pic is working, I will get more when I take back apart
http://mail.aol.com/38252-111/aol-6/...s=IMAG0156.jpg
Old 01-04-2014, 07:39 AM
Here's a pic looking straight down, you can see 2 studs near hpop. It's like an additional support bracket/pedestal
http://mail.aol.com/38252-111/aol-6/...s=IMAG0163.jpg
Old 01-04-2014, 08:43 AM
MisterCMK's Avatar
Avid Winter Hater
The pics are not working
Sent from my HTC6500LVW using IB AutoGroup
Old 01-04-2014, 10:16 AM
Ok, how's this
Old 01-04-2014, 10:36 AM
[/IMG][/IMG]
Old 01-04-2014, 10:37 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Old 01-04-2014, 10:39 AM
Stainless Steel or Titanium bolts? Arizona97 6.0L Power Stroke Diesel 6 08-31-2015 10:21 PM
Where can I find I/H bolts for waterpump upgrade Groundpounder0331 1994.5 - 1997 7.3L Power Stroke Diesel 11 07-14-2015 01:24 PM
Need help ASAP with rear turbo bolt LiftedBlackHD 6.0L Power Stroke Diesel 10 03-16-2015 07:04 PM
pic request! custom turbo pedestal Greg5OH Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 11-06-2014 03:32 PM
turbo rebuild and uppipes!! diehardstroker 1999 - 2003 7.3L Power Stroke Diesel 63 10-12-2013 11:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
