linear actuator & a tilt nose - Page 2 - Ford Truck Enthusiasts Forums
Old 01-19-2014, 11:47 AM
lens54's Avatar
lens54 lens54 is offline
lens54 is starting off with a positive reputation.
Drew...front end is all metal no fiberglass anywhere in my truck. Front end is very heavy and i wanted to make sure the actuators held. I used 2 x 850lb actuators. Overkill probably but i did not want it to have any trouble holding or pushing it. I searched for the best ones i can find and landed on this company. Linear Actuators | Quality DC Actuators by Progressive Automations . Very high quality actuators.
This forum only allows to add pictures if you have them on the web somewhere which i do not so not sure how to get pics to you. If you can put your email here feel free i will send them to you.
Also see this post i found somewhere the guy with a 53 F100 documented in detail you may find it helpful. http://jniolon.classicpickup.com/til...gfulltilt.html.
Len
To tilt or not to tilt EBEAR 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 07-15-2016 10:24 PM
WDH Refresher PAWZ Guitar Company Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 6 10-02-2015 08:33 AM
Ignition Actuator, the easy way Redrocket9.0 1987 - 1996 F150 & Larger F-Series Trucks 15 08-26-2015 10:46 AM
Door Lock Actuator Replacement Procedure (Enhanced) CUINAK Excursion - King of SUVs 60 06-22-2014 04:37 PM
Comments/suggestions about my tilt front end bracket idea? lvin4jc 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-22-2010 10:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
