'07 Plugs Change - Questions - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 01-03-2014, 04:20 PM
Goof008 Goof008 is offline
Goof008 is starting off with a positive reputation.
OK, I've read all the posts, I watched the videos but I have a couple of questions:
Some people say the engine should be warmed a little, some say it should be cold. I am in Michigan, so cold so cold won't be a problem! Just want to make sure to do it the best way.
I have been running combustion chamber cleaner in for a few tanks now to help as much as possible...and because I was going to do it myself, then I decided to have the Ford dealer do it until they wanted $95 a plug for each one that broke! Now I am doing it myself!
Does using an impact wrench (I have a Rigid 18v) to loosen the plugs help?
Lastly...Gumout (carb cleaner) or PB Blaster?
Any help would be great!
PS - Makuloco200...great videos
Old 01-07-2014, 08:03 PM
irishpride1 irishpride1 is offline
irishpride1 is starting off with a positive reputation.
I used a ratchet and just took my time. nice and slow steady pressure. good luck. none of mine broke thank the stars, but be sure to torque the back or you may get a slight gas smell. I did. I forgot the tq but it's googleable
Old 01-11-2014, 12:47 AM
jdm5630 jdm5630 is offline
jdm5630 is starting off with a positive reputation.
I sprayed pb blaster and left overnight. I also went with the ratchet and took my time. I did it with a cold engine. I only had 2 break #4 and #8. I would buy the extractor tool just incase. If you dont use it you could always return it
Old 01-11-2014, 06:15 AM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is online now
alwaysfords41 is gaining momentum as a positive member of FTE.
4 and 8? Ouch.
Old 01-11-2014, 10:11 AM
D-Rock D-Rock is offline
D-Rock is starting off with a positive reputation.
One thing you didn't mention was a Lisle tool (assume you may already have purchased one). Do not attempt w/o this. otherwise if you break a plug you are SOL.
This was my experience, but Makuloco200 did an awesome job, as well.
http://www.ford-trucks.com/forums/10...iles-pics.html
Dad's Air Cleaner Gary Lewis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 106 11-29-2016 09:58 PM
78 Ranchero pilot Jerry Kaye New Member Introductions 2 10-14-2014 10:17 AM
Early 99 Turbo and Exhaust Questions Haggs21 1999 - 2003 7.3L Power Stroke Diesel 12 03-20-2014 03:21 PM
Veteran needs help SDElwood Tennessee Chapter 6 02-23-2014 01:24 AM
Rough after Oil Change... dinebito 6.0L Power Stroke Diesel 17 02-11-2004 08:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
