Poorly illustrated door latch upgrade
After reading everything I could find on replacing the door latches I spent the last couple of evenings working on mine. I'm using latches from a Colt Vista wagon. They are nice and compact and have more features than the aftermarket bear-claws.
Latch mounted in filler plate. Rod was cut and bent to line up with door handle.
Original lines of cut where pilot holes are drilled, had to expand to the red lines to get the latch in the door.
Rear shot of the cutout.
Mounted in door.
Striker mounted in jamb, I'm sure I will need to reinforce this a bit.
I originally cut the shaft off the handle and added a pawl where shown here. Handle is a little too loose this way. I'm going to redo with the uncut handle and gutted original latch to support the handle.I think I will eliminate the exterior front door locks and use solenoids, since it's a panel I'll keep the original back door lock for emergency entrance. I will use cable to attach to the inside handles.
The door now shuts very easily with minimal pressure. Really not a very hard job just takes a lot of planning.
Mounted in door.
Idaho Highboy
01-12-2019 06:53 PM
shooer
04-10-2008 06:17 PM
