302/C4 vs Flathead/T5
There isn't any trans with OD that will fit behind a flathead and clear the crossmember. You need to define "highway speeds", 60 - 65 on rural highways is do-able with just lower rear gears. If you want to go 75 in traffic then you need major upgrades to brakes, suspension, etc.
RSWhitmore, I'd be curious how you hooked up a clutch linkage? Are you using hanging pedals?
Another good point, I guess I would be content with 55-65mph which the C4 did fine when it was in my F100. Definitely dont want to have to upgrade the suspension, etc.
Thank you all, giving me a lot to think about and learned a few things.
Update: all my front end (fenders, hood, etc.) are off being media blasted.
I killed myself hunting for that unicorn. The short answer T-5... crossmember is "not frame" while also being frame - it provides torsional strength (frame twist when 1 wheel goes into a ditch etc).
T-5 is really the best current trans option at the moment.
here's a complete list of what I have figured out will go (verified by users who did the actual swap whenever possible):
Ford F1 series Transmissions swap
The thing that has me curios to those who did a ford SB (289/302/351w) with a T-5 which T-5 did you use, the chevy 350mt pattern from a S-10 or a ford pattern from a mustang (and then a total tail section swap).
It really isn't that big a deal. Just cut out the original transmission cross member. and bolt in a new one for the T5. That's probably the easiest modification I did. The independent front suspension, new rear suspension, and mid 80's 9" rear end was more work, but the transmission cross member was easy. The overdrive will definitely be worth the effort.
Thank you for the link, it has great information.
This the primary reason why I don't want mess with the frame, I want to keep the integrity of the frame. I also feel it will hold its value better in the future, not that I plan to sell but you never know. The C4 with the flatty is looking really attractive. I found the adapter kit for the C4/flatty from Speedway for about $399 and wouldn't require mods to frame. Of course I giving up the OD.
With a C4, you could run as low a rear axle ratio as 3.25, the torque converter would make up for some of the low end loss. I would recommend the Flat-O-Matic conversion over the Speedway kit, not based on personal experience but on hundreds of good reports on their products. The Flat-o-Matic
#28
#29
#30
