2008 6.4 Problem, Please, I Need help - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
Old 01-03-2014, 09:32 AM
70runner 70runner is offline
70runner is starting off with a positive reputation.
I have a 2008 6.4, Sinister EGR delete, DPF Delete, SCT Tuner.
The problem is it Starts perfectly fine and Idles fine for a few minutes. Then it goes into a terrible miss. Scan tool says #2 misfire, and something to with Contribution ??. I Can shut it off and wait a few minutes it starts up fine again and does the same thing. If I start driving it before the misfire occurs it seems to run fine going down the road. And a couple of times it has just died out while at idle.
I took the EBP sensor and tube off and cleaned them, no change still does the same thing.
I unplugged the EBP sensor thinking the computer will default to an acceptable pressure, no change still does the same thing.
I'm thinking it might be a tuner problem, but??
Old 01-03-2014, 10:05 AM
a4t1rat's Avatar
a4t1rat a4t1rat is offline
a4t1rat is starting off with a positive reputation.
Sounds like an injector problem, Are there any codes? you could try to reload the tune be sure the tuner is updated with the most recent files. if not that I would get it checked out to see it its a injector or o ring you dont want it wash the cylinder or crack a piston if it is a injector hanging up.
Old 01-03-2014, 07:11 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
injectors...should have codes, what are they?
Old 01-04-2014, 08:43 PM
reaganla's Avatar
reaganla reaganla is offline
reaganla is gaining momentum as a positive member of FTE.
X 3 sounds like an injector... did you ever notice any hesitation or miss at idle prior to this
Old 01-04-2014, 11:05 PM
No, I never noticed a miss before. Yesterday using the SCT tuner I put it on the tow tune. I had it on a custom tune before when I had the problem. This seemed to correct the problem. I started it and let it run for a while and no problems. I haven't driven it yet and now its -25 so I am going to wait til it warms up a little. Thanks for all the replies. I'll post an update when I get back to it.
Old 01-05-2014, 09:06 PM
brian1253 brian1253 is offline
brian1253 is starting off with a positive reputation.
What do your fuel filters look like?
Old 01-05-2014, 11:48 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
Quote:
They look kind a like a Cylinder about 4 inchs long. Lol. Had jump on that one.
Old 01-10-2014, 01:15 AM
Quote:
Lol got me flat out walked into that one.
To the op did you resolve the issue?
No boost Nativedancer76 6.4L Power Stroke Diesel 19 01-23-2015 11:25 AM
Misfire post coolant flush, egr and ebp sensor clean ajg617 6.0L Power Stroke Diesel 0 09-26-2014 09:53 PM
Problems after egr delete and oil cooler install keith2547 6.0L Power Stroke Diesel 5 02-01-2014 06:02 PM
2008 6.4L with codes, high idle & dead pedal. Merculous 6.4L Power Stroke Diesel 17 11-01-2013 11:02 AM
Can't boost over 20 lbss, low pressure and coolant doesn't get hot vpnwiz 6.4L Power Stroke Diesel 7 04-09-2012 10:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
