Rattling in front end drivers side - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 01-02-2014, 11:26 PM
Jimha4444 Jimha4444 is offline
Jimha4444 is starting off with a positive reputation.
Hi, new to the forum. Any help with my issue would be appreciated. I have an 07 expedition. Recently a rattling begins at certain RPMs 2000 -3000. The rattling is not isolated to acceleration, but this is where it is the worst. The weird thing is when I switch to 4A the noise goes away completely. I jVe replaced the shift motor on the transfer case and checked for any heat shield rattles. The noise sounds like a bunch of screws in a metal can rhythmically rattling. Any insight? I've kept in 4a as of late due to this issue. Would greatly appreciate some thoughts. Almost sounds like the front axle is half engaged. Thanks in advance.
Old 01-03-2014, 12:41 AM
bunky383 bunky383 is offline
bunky383 is starting off with a positive reputation.
if you think it sounds like front axle shafts are half engaged, it could be a bad integrated wheel end solenoid (IWE). vacuum is applied to each IWE, located on the end of the axle shaft in the knuckle, to keep in 2wd, and releases vacuum to apply/engage front axle shafts for 4x4 operation. if you have a vacuum leak in the lines going to either or both IWE's then there isn't quite enough vacuum to keep front axles from being fully disengaged.
4.6L Engine Rattle when accelerating. morris_506 1997 - 2003 F150 9 01-15-2017 10:46 PM
Weird rattling noise and ticking noise while idle nicholas116 2004 - 2008 F150 1 12-28-2016 08:15 PM
91 Ford f150 4.9l engine has rattle at 1500 - 1700RPMs spike150 1987 - 1996 F150 & Larger F-Series Trucks 7 04-04-2016 08:35 PM
F-250 Front Wheel Rattle/Clicking PW_SD 1999 to 2016 Super Duty 16 07-14-2013 01:02 AM
5.0 Explorer Noise In Engine hdrk2001 Explorer, Sport Trac, Mountaineer & Aviator 1 06-12-2003 10:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
