302 to 460 ... ?
302 to 460 ... ?
I have a 88 Bronco XLT, Auto, born with 5.0 EFI
Now , that 302 is on he's last miles .
My question is ...
Can a carburated 460 ( from a old ford motorhome ) can be a good
idea for a low budget engine swap ?
what are the things to look for !
Issues with tranny ?
with transfer case ?
Drive shaft ?
Harness ?
I can have that motorhome for free ..
Is that .. a cool project ... or a worst nightmare !
Thanks for the advices !
My question is ...
Drive shaft ?
Harness ?
on
Maybe.. depends upon your level of expertise. This is a powertrain swap not an engine swap because that big block will not bolt up to a small block trans, and you will have to make changes to the trucks fuel and ignition systems because none of the EFI stuff will work with a carbed motor.
Well , ...
Thank you for the advices . I will think about it ...
it seems to require much more than my knowledge of mechanics
and all this on tight budget ... ? not sure !
I thought a 460 would have been a really cool project .
But ... the rebuild of the 302 seems to be the obvious choice.
( or finding a cheap 351 !!! )
Thanks again !
Thanks again !
Well , ...
Thanks again !
Thanks again !
Also, the Exploder engines have the HO firing order, you'd just have to wire the distributor 1-3-7-2-6-5-4-8. I'm pretty sure that's what I did with my Bronco. One last thing, GT40P heads have a revised plug angle, so that may have some clearance issues with your exhaust. I would imagine stock manifolds should work fine, but I don't know what you have. If you don't want to have to worry about the exhaust, just get like a 96-98, I think that was the GT40 years
grab a 5.8 from an 88-91 bronco, f150,250,350 and drop it in. its a direct swap for your tired 5.8 except for a 5.8/AOD specific flexplate that you can get new at most auto parts stores for $60.
your stock 5.0 wiring harness will hook up to everything on the efi 5.8. I have done this swap on the same year bronco you have. once i had all the parts, did the swap by myself and this site in a weekend.
...my heart telling me , : " no replacement for displacement !!!! "
and ... my head saying : " avoid headache, ... 5.8 is plug and play ! "
well I let it sit .. for a while ...
talking to the financial minister ...
Thank you so much for all the tips , advices and suggestions !
my Bronk is sitting for more than a year now .
I have to do something .
Besides a healthy 351 will make plenty of power.
And stroker kits are CHEAP now days, for an easy 400 cubes.
A big plus for the 351 swap too, is being able to have EFI on the cheap . Sure you could get an EFI big block, but they're performance limited without spending a LOT of money, significantly more than a stroker kit for a 351.
Carbs don't like hills and weird angles. Makes no difference on a fuelie.
<table border="0" cellSpacing="0" cellPadding="6" width="100%"><tbody><tr><td style="border: 1px inset currentColor;" class="alt2"> Originally Posted by peganit2
</td></tr></tbody></table>
I dont know how many times I have heard this said. I have been wheelin since 1975, and I cant recall a single time that climbin a hill made any of my carbs stumble. Not sayin it dont happen but we do have some good sand hills here in Fla.
