Picture request
Picture request
I had to make a throttle cable bracket since all of the carbed trucks I found to get parts off were missing them. They had the cables just no brackets. So I don't think I have it routed exactly right and the pedal is stiff. So would someone take a picture of the way their throttle cable is run from the firewall to the carb. It doesn't have to be too detailed just so that I can see how straight it needs to be and where the curves are. Thanks
Thanks. I think it is as good as it is going to get unless I get a new cable. It is not in a bind or anything. I just wasn't sure because the cable comes out behind the valve cover but then has to run over 6" or so to attach to the carburetor lever, so it is "S" shaped. I wanted to make sure I had it right.
KsCop
02-21-2021 02:19 PM
PharmerChris
45
01-11-2020 01:08 PM
F-250 restorer
16
06-23-2019 12:39 PM
hharris8
08-08-2016 08:06 PM
