Wierd RPA (Rear Parking Aid) Issue
So I go out this morning and its maybe 25* outside. Start the truck, put it in reverse and the warning buzzer for the rear parking aid comes on. Look at the camera in the mirror, nothing behind me. Put it back in park and again shift to reverse. Same thing, camera comes on along with warning buzzer. Get out, walk to the rear, camera, sensors look clear. Get back in, same thing. Drive to town and do some errands, then stop by Ford. By this time it is a little warmer (33-35*) and the buzzer activation has stopped. Service dept stated they never heard of that one before and neither have I so................
Anyone have this happen?
I have found that condensation will sometimes freeze on or around one or more sensors, causing the truck to think there's an object there. If only one of the five (I think) sensors is frozen this will cause the buzz. I get it all the time here in MI. Once the ice melts or I clear the snow away all is good.
Mine acts up once in awhile but it's not really affected by the cold. Every so often it seems to be hyper-sensitive. It starts beeping like mad when there's nothing behind me within 20 feet. The wife has them on her Edge and they seem to work perfectly ALL the time.
It's 9 degrees F outside today and the truck's is working fine.
-Bobby
-Bobby
Just to set the tone. I have had back up sensors since 2000 in a DTS Deville. The had 2 yellow lights and a red over the rear window you see in the mirror and a chime when a yellow comes on and constant pinging on red at 6 inches, It works great. Ford. 2002, 2004, 2012. They all work poorly in cold weather. They also changed because the 04 broke sometime around 2010 and when replaced the sensitivity had increased. It was not adjustable. The sensors were not changed just the unit. The 2012 seems to act like the replacement. I don't know why they cant be made better. The 2000 Cady is far superior.
Just got back from the shop to address this. I had my annual service at Ziebart and figured that some moisture was in the connector(s) or sensor(s). The system works fine down to 20 degrees and below that I get a constant tone.
We hooked up the IDS and it showed that the passenger side outboard sensor was reading less than a foot. We took apart the sensor, blew it out with compressed air as well as the area around the sensor. Been working fine ever since.
Cold weather (frost), dirt on the sensors, soot on the sensors!!(deleted), after washing the truck, after driving through rain, anything that gets them damp will cause it to happen. Not a continuous thing and as previously posted they work all the time but sometimes things get in the way like dirt or snow or ice or they get wet. Small annoyance since it is usually short term.
Well, if your dealer is kind like mine, they'll hook up the IDS for you and you can see on the computer screen which sensor(s) think how far an object is from them. From there you can troubleshoot an individual sensor.
