Ok, what did I do? nav says 'No GPS' - cut the antenna wire - doah
if you were following, I got and installed an Airlift Wireless One and Viair 10007 on board air kit on my 12 dually. finished the OBA kit on Tuesday.
I ran the wires to the compressor thru plastic conduit, up thru the passenger side over the main harness connections behind the battery, over the top of the engine, and to the left side battery (with appropriate fuses).
the control signal is connected to upfitter 1. first wires connected there.
man they are hard to connect to.. getting off the covering and crimping the wires.
only wires in the cab were the passthru wire and the upfitter end, now connected.
but my Nav head now says No GPS all the time.
the only similar topics I found on FTE were related to installing a new nav unit, and not getting the antenna seated.. I didn't touch anything behind the dash.
edit: hoping it was some electrical interference I pulled the fuse on the hot lead across the top of the engine. no change.
but I shall go look.
the upfitter wires were not taped.
did I mention I hate coincidences like this.
unfortunately didn't solve the No GPS problem.
I am working a temp assignment out of town so can't take the truck to the dealer. (they don't have anyone to work on it today anyhow).
they suggested the master rest on the nav (have to find that)
or disconnect the batteries.
In all seriousness, it only takes about 2 minutes to pull the dash panel and remove the head unit to take a look at the back. The satellite antenna wire connection is pretty lame and it wouldn't take much to yank it loose.
That is usually where I start and you would be surprised at how much of my finest swearing that some of these inanimate objects can take!
anyone know where the GPS antenna module is?
