CODE 26 - Ford Truck Enthusiasts Forums
CODE 26
Old 01-02-2014, 11:59 AM
bumper.45acp bumper.45acp is offline
bumper.45acp is starting off with a positive reputation.
CODE 26
Pulled this code yesterday KOER...best i can tell it is a MAF code or a TOT code, which my truck has neither. Not sure what it could be. Any ideas? Also got a 34 and a 41 if that makes a difference. Thanks.
Old 01-02-2014, 12:01 PM
also there where no KOEO codes.
Old 01-02-2014, 12:53 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Run the test again. I agree, 26 doesn't seem to be the right thing for your truck. Maybe you have the wrong computer if you are getting this code again?
Old 01-02-2014, 02:08 PM
I ran it three times yesterday, because i knew i had to be counting wrong, but i will run it again just to be sure. Would it even run if it did have a MAF computer or computer for an E4OD?
Old 01-02-2014, 05:25 PM
Franklin2's Avatar
Are you positive someone didn't do a MAF swap on your truck? I don't know too much about it, but don't they make kits for this so you can modify the engine?
Old 01-02-2014, 06:13 PM
bill06447 bill06447 is offline
bill06447 is gaining momentum as a positive member of FTE.
26 is also the code for transmission temperature out of range.... ~Bill
Old 01-02-2014, 06:35 PM
Franklin2's Avatar
Quote:
His tranny(the AOD) doesn't have this sensor.
Old 01-02-2014, 08:10 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
According to the 1986 FoMoCo Powertrain Control/Emissions Diagnosis Manual, a KOER Code 26 is not possible for any engine in a Light Truck application that year.
Possible reasons you might see this:
- You're misinterpreting codes or pulling them incorrectly
- Some PO replaced the computer with the wrong one
Old 01-03-2014, 10:12 AM
There has not been a MAF swap on the truck (yet). I am 100% sure that I pulled the codes correctly. It is entirely possible that I counted wrong, but I did count the other codes right. I am going to reset the codes and pull them again tomorrow then see what it says. I was pulling codes to see about a fuel mileage issue (4-6 mpg), which I think my EGR codes may be the cause of that. Thanks for the input guys.
Codes kbf1961 6.0L Power Stroke Diesel 7 10-17-2015 10:05 PM
Color Code tlcsr66 Excursion - King of SUVs 1 05-14-2014 04:08 PM
Axle Codes 1972RedNeck 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-30-2012 11:33 PM
What are the "Build Sheet" Codes? TallPaul 1987 - 1996 F150 & Larger F-Series Trucks 14 11-15-2001 05:38 AM
Engine code 1451 flatbranch 1997 - 2003 F150 4 06-02-2001 10:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
