Questions/clarifications about the 6.2L engine
Hey guys, help me here with a few questions. I have had my 2014 6.2L for about 2500 miles now and have been reading on here to ed-u-ma-cate myself about this engine. I have knowledge about the old 5.8 FI and the EEC-IV computer system with a lean towards the performance side. I have read somewhere that the 6.2L is not direct port fuel injection but looked at the engine bay (which is mostly under the dash) and think I see the fuel rails where they should be for DI. also I knew this engine has two plugs per cylinder and saw how the second plug is served from the same coil pack but under the valve cover.
Does anyone have a source for a drawing/picture/schematic of the 6.2L? I'm an engineer by profession and have a "need to know".
Also, is the FI a return style to the tank?
This is certainly not a direct-injection engine, but rather a typical port injection motor. The reason dual plugs are used is because of the large size of the valves, and the fact that they are angled into the top of the cylinder. Having two different plug locations ignites the mixture in this engine more efficiently than one plug could. Dual plugs is not a requirement for DI, either.
Regarding the fuel lines, I am not sure if this is a returnless system or not.
This engine is a mix of old-school design with some modern tech thrown in. The good parts are the cast iron block for greater longevity. I'm not sure why Ford would waste the effort to make an OHC engine and yet give it only two valves per cylinder. Granted, the valves are large, splayed, and operated by roller rockers, which is unusual; but only running single cams limits VVT usefulness, which can be very beneficial to output. This engine does run cam phasers, but unfortunately it can only vary the timing of both intake and exhaust valves together. Ford's own new 5.0L V8 is a 32 valve engine with much greater effect from its VVT. It seems the 6.2L might have been a better design as a pushrod engine...e.g. the GM 6.2L engine?
I'm sure the coil is designed to push a spark off each plug simultaneously. This is not uncommon to use a single coil to fire dual plugs. Up to '99, Mercedes used 3 coils to fire all six plugs on its inline 6 engines using the 'wasted spark' principle; I can assure you all 6 cylinders were firing. Subsequently, starting on it's '98+ V6 and V8 engines, Mercedes used a single coil to fire twin plugs per cylinder. And of course, modern Dodge Hemi engines also use two plugs per cylinder.
2 plugs vs 1 plug is due to combustion chamber design. Splayed valve hemi types (Ford 6.2/Dodge semi hemi) aren't as efficient/fast burning compared to a wedge(GM single plug quench style that's been refined over 60 years). Why only a 2 valve? Goals and cost. It meets power, economy, nvh, emission standards, etc while requiring fewer machining steps and parts. Keeping it simple. They flow plenty of cfm as is. The pushrod Ford production gas v-8 died with the 302/351. They aren't going back it. That being said, if the 250/350 folks are happy, I'll be downright thrilled in a 150 fx4.
Emissions is getting to be as important a 'stat' as horsepower, torque, and fuel economy. Motor Trend now publishes how many pounds of CO an engine produces, on all the vehicles it tests. Don't be surprised if this doesn't appear on vehicle window stickers soon, and you're taxed if you buy a vehicle with a high CO rating.
