Questions/clarifications about the 6.2L engine - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 01-02-2014, 08:06 AM
JimRay's Avatar
JimRay JimRay is offline
JimRay is starting off with a positive reputation.
Hey guys, help me here with a few questions. I have had my 2014 6.2L for about 2500 miles now and have been reading on here to ed-u-ma-cate myself about this engine. I have knowledge about the old 5.8 FI and the EEC-IV computer system with a lean towards the performance side. I have read somewhere that the 6.2L is not direct port fuel injection but looked at the engine bay (which is mostly under the dash) and think I see the fuel rails where they should be for DI. also I knew this engine has two plugs per cylinder and saw how the second plug is served from the same coil pack but under the valve cover.
Does anyone have a source for a drawing/picture/schematic of the 6.2L? I'm an engineer by profession and have a "need to know".
Also, is the FI a return style to the tank?
Old 01-02-2014, 08:57 AM
Go Big or Go Home! Go Big or Go Home! is offline
Go Big or Go Home! is starting off with a positive reputation.
Can you post your findings, I just bought a 2014 SD 6.2L also.?
Old 01-02-2014, 09:15 AM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
have you read the "read first" thread in the 6.2 forum? may answer a lot of your questions.
Old 03-17-2014, 11:06 AM
troverman's Avatar
troverman troverman is offline
troverman has a great reputation on FTE.troverman has a great reputation on FTE.troverman has a great reputation on FTE.troverman has a great reputation on FTE.troverman has a great reputation on FTE.
This is certainly not a direct-injection engine, but rather a typical port injection motor. The reason dual plugs are used is because of the large size of the valves, and the fact that they are angled into the top of the cylinder. Having two different plug locations ignites the mixture in this engine more efficiently than one plug could. Dual plugs is not a requirement for DI, either.
Regarding the fuel lines, I am not sure if this is a returnless system or not.
This engine is a mix of old-school design with some modern tech thrown in. The good parts are the cast iron block for greater longevity. I'm not sure why Ford would waste the effort to make an OHC engine and yet give it only two valves per cylinder. Granted, the valves are large, splayed, and operated by roller rockers, which is unusual; but only running single cams limits VVT usefulness, which can be very beneficial to output. This engine does run cam phasers, but unfortunately it can only vary the timing of both intake and exhaust valves together. Ford's own new 5.0L V8 is a 32 valve engine with much greater effect from its VVT. It seems the 6.2L might have been a better design as a pushrod engine...e.g. the GM 6.2L engine?
Old 03-19-2014, 02:22 AM
Evil Elf Evil Elf is offline
Evil Elf is starting off with a positive reputation.
Not sure i get the point about dual plugs since there is only one coil per set and spark will go to the plug of least resistance. this is evident by the reports of people that have 90k miles that are changing them out. If there were a coil per plug i might.
Old 03-19-2014, 06:45 AM
troverman's Avatar
I'm sure the coil is designed to push a spark off each plug simultaneously. This is not uncommon to use a single coil to fire dual plugs. Up to '99, Mercedes used 3 coils to fire all six plugs on its inline 6 engines using the 'wasted spark' principle; I can assure you all 6 cylinders were firing. Subsequently, starting on it's '98+ V6 and V8 engines, Mercedes used a single coil to fire twin plugs per cylinder. And of course, modern Dodge Hemi engines also use two plugs per cylinder.
Old 03-19-2014, 11:34 PM
Lectrocuted Lectrocuted is offline
Lectrocuted is starting off with a positive reputation.
2 plugs vs 1 plug is due to combustion chamber design. Splayed valve hemi types (Ford 6.2/Dodge semi hemi) aren't as efficient/fast burning compared to a wedge(GM single plug quench style that's been refined over 60 years). Why only a 2 valve? Goals and cost. It meets power, economy, nvh, emission standards, etc while requiring fewer machining steps and parts. Keeping it simple. They flow plenty of cfm as is. The pushrod Ford production gas v-8 died with the 302/351. They aren't going back it. That being said, if the 250/350 folks are happy, I'll be downright thrilled in a 150 fx4.
Old 03-27-2014, 01:53 AM
Quote:
I did not realize how many engines used wasted spark after a little research I see the emissions benefit. I guess I normally look at things from a performance perspective and probably why i overlooked it.
Old 03-27-2014, 06:45 AM
troverman's Avatar
Emissions is getting to be as important a 'stat' as horsepower, torque, and fuel economy. Motor Trend now publishes how many pounds of CO an engine produces, on all the vehicles it tests. Don't be surprised if this doesn't appear on vehicle window stickers soon, and you're taxed if you buy a vehicle with a high CO rating.
Another defector from the 6.0L diesel to 2016 6.2L whalerron 6.2L V8 17 11-20-2016 11:43 PM
2016 Contractor Boddied F350 DRW 6.2L Question CAGML 1999 to 2016 Super Duty 15 02-09-2016 12:21 AM
Does the 6.2L have a engine name? Strokin-A-2010 6.2L V8 5 01-01-2016 07:45 PM
What's the engine name for the 6.2L Strokin-A-2010 1999 to 2016 Super Duty 5 12-30-2015 03:47 AM
6.2L V8 - really 2 spark plugs? troverman 1999 to 2016 Super Duty 19 02-09-2015 05:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
