6.2L V8 Discuss the 6.2L V8
Speed limiter?
Old 12-17-2013, 06:29 PM
saltbranch's Avatar
saltbranch
saltbranch is offline
Speed limiter?
How can i do away with that? Can the tire sensors be disabled? Is the warranty affected if disabled?
Old 03-17-2014, 12:30 PM
troverman's Avatar
troverman
troverman is offline
What do you mean, speed limiter? The top speed governor of like 100mph?
Old 03-17-2014, 09:14 PM
SoYouCanSuperDuty's Avatar
SoYouCanSuperDuty
SoYouCanSuperDuty is offline
You talking about governor? My Key?
Old 03-20-2014, 10:41 AM
saltbranch's Avatar
saltbranch
yes that is what I want bypass/turnoff
Old 03-20-2014, 01:54 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Tuner.
If you blow it up, your warranty will not cover it.
TPMS may or may not disable with tuner.
Old 03-20-2014, 04:19 PM
RigTrash601's Avatar
RigTrash601
RigTrash601 is offline
Originally Posted by 85e150six4mtod
Tuner.
The tuner won't affect the TPMS. I've raised the Top Speed on mine, the tuner won't allow you to defeat it, I've left the Rev. Limiter alone
Old 03-21-2014, 07:42 PM
saltbranch's Avatar
saltbranch
TPMS...whats that stand for?
Old 03-21-2014, 07:47 PM
RigTrash601
Tire Pressure Monitoring System.. Lets you know when a tire is low. The tuner won't affect that.
Old 03-21-2014, 07:55 PM
saltbranch's Avatar
saltbranch
On the gas trucks, does a tuner kill the warranty like it does on a diesel?
Old 03-21-2014, 08:13 PM
RigTrash601
According to who you talk to. I personally haven't had any issues, but I haven't used the truck as a race car either. Most of the guys I knew that had issues with the diesels, had a tuner, straight pipe, delete kits, etc.. like on the 6.0 diesel, alot of folks tuned them and didn't restud the heads and warped them because the engine couldn't handle the added HP in stock configuration. I run a superchips cortex tuner, you can tweak it to your liking by changing shift points, raising the rev. limiter, etc. I just run a "preloaded" performance tune with a raised top speed. The tuner won't completely defeat the top speed limiter. Not sure what my top speed is now, I just know it won't cut off at 100 MPH.
Old 03-22-2014, 07:19 AM
troverman's Avatar
troverman
Just out of curiosity, why do you guys want to go more than 100mph in a pickup? The F-150 might be OK, but man, a 4-wheel drive Super Duty is not designed to go fast like that. The slightest corner becomes scary if you hit any kind of a bump....
That being said, I'll probably add the 5-star tuner to my truck once the powertrain warranty expires. Not for top speed, but just for better midrange power and to eliminate the stupid throttle reduction until 3500RPM, etc.
Old 03-22-2014, 07:47 AM
RigTrash601
I don't have a SD pickup, I'm driving a F150. I don't drive that fast, but there are times I need the speed!
You'll see a big difference in power with the tuner, they really wake your truck up, and you can read / clear DTC's, recalibrate the speedo, mileage tunes, towing, etc. I love mine, not just for the performance aspect.
Old 03-22-2014, 07:51 AM
troverman's Avatar
troverman
Right, I see you are driving an F-150 (looks great, BTW). I was just referring to the OP who does drive a Super Duty...
Old 03-22-2014, 08:18 AM
RigTrash601
Yeah, I Love the truck, but it's pretty much a pavement queen. Just don't seem right getting her off in the woods! I'll probably trade it later this year for a FX4 with the 6.2L. Wish I could keep it and get a new one, but I can't see that happening. Even with it being a F150, it goes alot faster than I need, it will scare the s**t out of you, the 6.2 in the F150 is an animal, I've completely turned off the traction control one time talk about a "wild ride", won't do that anymore!, can't say for the 250, never driven one with the 6.2. What kind of fuel mileage do you get with the SD / 6.2?
Old 03-22-2014, 08:23 AM
troverman's Avatar
troverman
Pretty dismal, usually 9-10 in town, 14 on the highway. These are empty numbers, but winter driving (I keep the hubs locked in all winter which might cost me 0.5-1mpg).
Now that I have 11k on the truck, this summer I expect maybe 11 in town and 15-16 highway.
Is your 150 an Ecoboost or 5.0?
Quick Reply: Speed limiter?
