fresh build 306 manifold vacuum
Old 01-01-2014, 03:10 PM
outcrydrummer's Avatar
outcrydrummer
outcrydrummer is offline
I just verified my timing and it looks fine.
Hooked up a vac gauge to the manifold and got 15-16 hg at 850rpm idle.
Seems like I read it should have 18-20 and be steady.
What is the most likely cause of this?
Any trouble shooting tips?
Thanks
Old 01-01-2014, 03:28 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
is the motor stock or ? also what carb do you have
did you adjust the mixture screws ?
Old 01-01-2014, 03:48 PM
outcrydrummer
Mostly stock. Flat top pistons. Erson mild cam.....484 lift and 214 duration.
No valve train noise and no notieacable huge issues.
I do suspect my distributor of being crap but verified timing is close.
Edelbrock 600. Did adjust the screws at rifle but only briefly.
Old 01-02-2014, 09:40 AM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
The slightly low vacuum is probably because of the cam. With those specs it should have a reletively smooth idle. Just slightly lumpy. I am guessing that Erson cam has a dual pattern Lobe Center. Probably like 107 degrees and 117 degrees. What ever it's specs are a general rule of thumb is the more the Lumpy a cam is the less vacuum siganal will be in the intake manifold.
Old 01-02-2014, 09:52 AM
outcrydrummer
OK thanks for the info. I'm really trying to eliminate possibilities. My motor starts and runs fine.....but isn't making any power.
Old 01-02-2014, 10:01 AM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
I think it's in that Dizzy also. It is always best to fix what you know is broke 1st. Then move on. Get a new Dizzy so your timing marks won't jump around. Timing of when those plugs fire is HUGE towards power.
Old 01-02-2014, 10:33 AM
outcrydrummer
Well I got another timing light on it and verified timing was consistent but I didn't check if the mechanical or vac advance was working or how good the coil is. I've take. That dizzy out before and had the shaft be very hard to turn. I'm replacing all that this weekend and if that doesn't help I'm gonna compression check all the cylinders and go from there.
Old 01-02-2014, 01:26 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Good Plan.
RamRod_
10-17-2021 09:47 PM
78 Ford F150 460
1978 - 1996 Big Bronco
06-07-2017 10:47 PM
lee
08-03-2015 11:30 AM
flaty 72
07-14-2014 04:07 PM
hoxiii
08-24-2006 06:13 AM
Quick Reply: fresh build 306 manifold vacuum
