Throttle body spacer - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 01-01-2014, 08:38 PM
JAE88 JAE88 is offline
JAE88 is starting off with a positive reputation.
Question Throttle body spacer
Has anyone tried a throttle body spacer on a SD with the 6.2? If so, did it help any?
Old 01-01-2014, 09:12 PM
jeepnford jeepnford is offline
jeepnford is starting off with a positive reputation.
Most of that stuff helps separate you from your money. I put an intake spacer on a 5.0 FI engine once to clear some fancy valve covers. It made big claims about all the extra power I would have. I couldn't tell any difference.
Old 01-01-2014, 09:44 PM
I figured that. I had one on my old 5.4 and made 0 difference, but just thought i would ask and check to see if maybe the 6.2 would be different.
Old 01-08-2014, 08:23 PM
BlueOvalJunkie11 BlueOvalJunkie11 is offline
BlueOvalJunkie11 is starting off with a positive reputation.
i think the best bet for power on these engines is a tuner and exhaust
Old 01-08-2014, 08:28 PM
I have a 5** tuner on the way. Now i just need to figure out what i will do with the exhaust.
Old 01-08-2014, 08:32 PM
what cab configuration you got?
Old 01-08-2014, 08:53 PM
It's a 4 door
Old 01-25-2014, 07:12 PM
Jamie Mendell's Avatar
Jamie Mendell Jamie Mendell is offline
Jamie Mendell is starting off with a positive reputation.
I did five star 93 performance tune made a big difference on my 6.2 limited also have k&n cold air . This truck rips now
Old 02-13-2014, 12:08 AM
Zecca93 Zecca93 is offline
Zecca93 is starting off with a positive reputation.
i did a throttle body spacer with an airaid cold air intake for my 6.2 SD..installed em both at the same time and noticed a difference but then you just get used to it so in the long run dosent really matter.. throttle seemed more responsive tho with a little more torque
Old 06-12-2014, 11:56 PM
IKEA52 IKEA52 is offline
IKEA52 is starting off with a positive reputation.
Quote:
Hey Zecca93,
What kind of throttle body spacer did you use with your Airaid CAI?
Old 06-21-2014, 04:04 AM
djm1204's Avatar
djm1204 djm1204 is offline
djm1204 has a very good reputation on FTE.djm1204 has a very good reputation on FTE.djm1204 has a very good reputation on FTE.djm1204 has a very good reputation on FTE.
will exhaust make much difference ? DO I need a tuner to get that difference ?
Thanks in advance for responses
Dan
Throttle body spacers stump.66 1978 - 1996 Big Bronco 42 05-21-2015 05:47 PM
Intake spacer (elbow) torque spec? Psyclopse Excursion - King of SUVs 0 05-07-2015 02:02 PM
Throttle Body spacers 71'3604speed 1987 - 1996 F150 & Larger F-Series Trucks 4 12-07-2012 02:43 AM
5.4 throttle body spacer bigal53021 Modular V8 (4.6L, 5.4L) 3 10-16-2012 10:02 AM
Throttle Body Spacer ssolid Excursion - King of SUVs 2 09-18-2012 08:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
