lowering the front end
Old 01-05-2014, 04:59 PM
AXracer's Avatar
AXracer
AXracer is offline
First law of vehicle modification:
Every 'unique" modification will require be at least 6 more. Each will be more complex and costly than the last.
Second law:
Soon the progression will often come a point where there is no solution, which will bring clarity why the first modification is not often attempted.
Third law:
When reinventing the wheel there is a high risk of running over one's own foot.
Old 01-06-2014, 05:18 PM
vintage tin's Avatar
vintage tin
vintage tin is offline
well i guess no one on the board has ever taken one of these columns a part.
maybe l should post some pics,not much stuff inside the column.this will be very easy to shorten.
AX, thanks for that incite .l kind of feel like Christopher Columbus on his maiden voyage .
l sure do respect your knowledge,but maybe its time to take the blinders off and support some new ideas,not that this is new or even my idea,like were would we be if nobody ever tried the MII or the CV,dodge what ever.i mean i just dont get it.anyway thanks for your help and i do mean that,i just dont always get were you are coming from.
Old 01-06-2014, 07:47 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
The outer tube comes off the column, but the inner shaft is one piece. You have to take the steering box apart to get it out. Or cut it and weld it back together, which I do not suggest you do.
breakfree
50
07-22-2021 08:36 AM
Hackster1
77
02-15-2019 01:14 PM
HellRaiser46
1947 and Older Ford Trucks
54
12-18-2017 04:54 AM
51dueller
47
02-16-2016 06:54 PM
Dcabe1210
12-18-2014 01:12 PM
Quick Reply: lowering the front end
