Rerouting alternator main cable
Old 01-01-2014, 02:13 PM
78fordman's Avatar
78fordman
78fordman is offline
I was reading Ed's website ficmrepair.com, and it says one thing that would help with getting battery voltages up quicker is to take a wire straight from the main post on the alternator and connect it to the batteries. In his information he says the alternator does not charge until the glow plugs are off. So there must be a relay somewhere to disconnect the alternator from the batteries while the glow plugs are on. Where is this or how does it work?
Old 01-01-2014, 04:42 PM
retiredinstructor's Avatar
retiredinstructor
retiredinstructor is offline
The alt does charge batts during glow plug opperation however the glow plugs and injectors are using most of the amps untill glow plugs turn off
Old 01-01-2014, 04:59 PM
FICMrepair.com's Avatar
FICMrepair.com
FICMrepair.com is offline
Former Vendor
Retiredinstructor is correct. This has been on my list of things to correct on the web site for quite some time, in fact - now done thanks to this thread (thanks fordman!) and bismic letting me know about it (more thanks!).
There is no relay, just an undersized alternator. While the alternator DOES charge as soon as it spins up, it does not have the capability to provide enough current to offset the draw from the glow plugs. Tack on the propensity for folks to run their blower motors/heated seats/radios, etc right away and the result is a stressed out FICM. Of course, the issue is exacerbated further by shorter trips and other regular use cases.
I run DC Power's 270XP alternator on my truck and have seen HUGE gains in the after-start voltage number department as a result. Let me know if I can hook you up with one of these bad boys for a few nickels off of what you can get them for on the DC Power site (though, really, the 185amp OEM unit is a huge upgrade all by its lonesome for half the money, even if it, too, doesn't quite cover this draw). The choice of which one is best is largely dependent on the duration of trips, the frequency of the shorter trips, and of course what other goodies (snow plows, inverters, and the like) you may be running.
Old 01-01-2014, 09:32 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
You should still upgrade or tighten you ground wires from the engine to the battery's/frame. I used 2/0 for both ground & alternator upgrade.
Old 01-01-2014, 10:34 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Here is a Pic of what DC Power sent me with my Alternator and this is How they told me to Run it
The grey part of the wire is a Fusable Link
here is More
Ford Truck Enthusiasts Forums - BLADE35's Album: DC Power Alternator & Wire Upgrade
Old 01-01-2014, 11:10 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Bismic is taking credit for that info huh?
Josh
Old 01-02-2014, 06:27 AM
bismic's Avatar
bismic
bismic is online now
Received 2,448 Likes on 1,696 Posts
I simply told him of this thread and the ridiculous responses it might (er will probably) get. No one was "taking credit" for anything as you put it, that was Ed being gracious.
Oddly enough, the post (#3) below is from a person (who claims to be a Professional Engineer - not sure what discipline though) on a thread over on TDS.
http://www.thedieselstop.com/forums/...nators-402361/
"In modern vehicles -- all of them, not just the ones with Diesel engines or dual alternators -- the alternator(s) is turned off while cranking to reduce the load on the starter motor and battery current.
The alternator remains off until a stable idle is achieved, then is gradually and smoothly ramped up from zero to full output, avoiding the sag & bump in idle speed that would occur if you just suddenly switched the alternator on. But this doesn't take a minute or two; it takes maybe 10-20 seconds."
I am not posting the above for any reason other than curiosity of how/why he could make the statement that the unit would "remain off until a stable idle is achieved", and to also comment on his belief that apparently there are controls in the alternator for a gradual ramp up (like a motor soft-start perhaps?). A few "technical" comments on his post might be informative.
Old 01-02-2014, 07:17 AM
Bullitt390's Avatar
Bullitt390
Two Alternators ?? - Diesel Forum - TheDieselStop.com
You can see voltage is held back during KOEO and during crank in my video, however the alternator is has full voltage on the excite wire as soon as the key in in Run.
Josh
Old 01-02-2014, 07:19 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
Josh
I agreed with you since somebody claimed there was a alternator delay when starting We know the stock alternator output can't handle the glowplugs and voltage drops because of alternator saturation Both mark and you have been very generous with your help/posts on this forum
Old 01-02-2014, 08:28 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Josh
I know that you did this and so did I but you had your up and so I did not bother with posting.
But I got the same results as you did. What I was watching with mine was amps on the B+
or alternator output cable and also voltage. Just as soon as it is turning it is making power.
Would be of interest to see how the dual alternator acts.
After the "My alternator is taking a crap" Thread I also upgraded mine to the HD 140 AMP
top dual unit with a smaller pulley. I now see a much faster rate of recovery after starting.
Sean
Old 01-03-2014, 12:02 AM
FICMrepair.com
Former Vendor
Here's how I routed my DC Power cable kit. Note that orders made through us provide the longer length wiring necessary to allow this path without any extra increase in cost. You really want to avoid the heat from the CAC tube.
Y2KW57
206
06-02-2023 09:08 AM
Herb Bell
08-02-2019 11:21 PM
MC5C
07-02-2012 09:59 AM
429poweredf350
02-08-2011 01:47 AM
Polkster
09-27-2009 06:18 PM
Quick Reply: Rerouting alternator main cable
