Sponsored by: Halo Lifts
2015 F-150
  #61
Old 01-05-2014, 04:05 PM
paredneck33's Avatar
paredneck33
paredneck33 is offline
What small diesel? I thought Ford was attemit about no diesel in the F150 line up. Did that change? Also I'd be willing to bet that the 2.7 will be geared more to the guys that miss and want the Ranger. I could be wrong on that though.
  #62
Old 01-05-2014, 04:28 PM
Tofan's Avatar
Tofan
Tofan is offline
Tom,
Let me be the first to say that the vehicle you pointed out that the military uses, is no way a "comfortable" ride. They break all the time and ride like they have no suspension. MRAPs are great at what they do, which is to protect the individuals inside, but the suspension is no way the result of "great thinking" rather the lowest bidder that the military felt best showed what they were looking for.
Anyways, to be on topic, it will be great to see what the new F-150 will look like, and maybe this aluminum move will be the way of the future for f150s, 1500s alike. It will be extremely surprising if they don't include a diesel in the lineup for the 150. When every other truck manufacturer does something and the third one doesn't follow with their "own" version it usually means something.
  #63
Old 01-05-2014, 04:31 PM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
RISUPERCREWMAN is offline
With Ram already offering a small displacement diesel in the mix, & if GM follows suit Ford will have to offer a diesel in a F-150 engine line up or lose much market share! Its all about supply & demand driven by market availability! Ford had better wake up!
  #64
Old 01-05-2014, 04:41 PM
Tom's Avatar
Tom
Tom is offline
Originally Posted by Tofan
Tom, Let me be the first to say that the vehicle you pointed out that the military uses, is no way a "comfortable" ride. They break all the time and ride like they have no suspension. MRAPs are great at what they do, which is to protect the individuals inside, but the suspension is no way the result of "great thinking" rather the lowest bidder that the military felt best showed what they were looking for. Anyways, to be on topic, it will be great to see what the new F-150 will look like, and maybe this aluminum move will be the way of the future for f150s, 1500s alike. It will be extremely surprising if they don't include a diesel in the lineup for the 150. When every other truck manufacturer does something and the third one doesn't follow with their "own" version it usually means something.
Of course an MRAP isn't comfortable. I don't think I've ever driven a military truck that was. But they ARE heavy duty, and they happen to have coil springs. In fact there are versions of the HEMTT that have coil spring front ends.
  #65
Old 01-05-2014, 04:44 PM
Go Big or Go Home!'s Avatar
Go Big or Go Home!
Go Big or Go Home! is offline
I think the ecoboost with the twin turbo's is pretty much a diesel equivalent. I would rather have a gas powered turbo than a stinky,expensive, high maintenance, and increased fuel costs of owning a diesel in a half ton..,And that is assuming the FIAT built 8 spd tranny will even be dependable,, I am sure the Ram forums will have its fair share of posted issues..If it were a Cummins it would be more credible. I don't see chevy bringing the duramax/Allison to there 1/2 ton market. if Ford can tweek the 3.5 EB to get a few more TRUE mpg's out of it then I still see FORD holding serve..
  #66
Old 01-05-2014, 05:46 PM
tseekins's Avatar
tseekins
tseekins is online now
Received 1,215 Likes on 798 Posts
Originally Posted by Go Big or Go Home!
no disrespect intended but for every guy like you who posts "never had a problem" there are just as many others who have.. there is no good truck bad truck issue, they all have the same parts. Every day it seems someone else posts "I thought I didn't have the CAC issue but it happen to me" post. There wouldn't be several class action lawsuits going on at this time if there were not enough guys who had the CAC issue. I am glad to hear your truck is riding good but don't discount the guys who are or have been stuck with this issue. I was kidding about the max-tow topic with the 2.7L
Never said the problems didn't exist, I was simply illustrating one method that may help reduce or remedy the issue based on several opinions from experienced diesel owners from all makes. It has worked for me. But who knows, I could be a victim of this issue and if I am, I'll address it. Till then, life is good.
  #67
Old 01-05-2014, 10:38 PM
hsfbfan's Avatar
hsfbfan
hsfbfan is offline
Ram's 8 speed is made by ZF, not Fiat. The F-150 head engineer has said repeatedly that there will not be a diesel in the F-150, the ecoboost engines are their response to diesel.
GM is not doing a diesel in their half ton's.
  #68
Old 01-06-2014, 12:52 AM
nojoke327's Avatar
nojoke327
nojoke327 is offline
Ram only did a diesel in their 1/2 ton, if you can even call it that to save a few customers. Ford and gm don't have loyalty issues when it comes to trucks and I'm pretty sure the f150 outsells the entire ram brand. If ford needs a diesel it will come out but I don't see ram and their junk outselling ford any time soon
  #69
Old 01-06-2014, 08:00 AM
Frdtrkrul's Avatar
Frdtrkrul
Frdtrkrul is offline
The 6.2L will not be offered in the F150s except the Raptor (if continued) . It'll only be in the Super Duty trucks. By 2025 the EPA will have it mandatory that all 1/2 ton trucks get a MINIMUM of 25mpg. If Ford puts any diesel in the new trucks probably be the 3.2L I5. Aren't they looking at putting military grade Aluminum as part of the new trucks?
I just really hope the aluminum does not compromise safety or strength of the truck and sour the name of Ford F-series.
  #70
Old 01-06-2014, 09:46 AM
RISUPERCREWMAN
Ford's current Eco-Boost does not get the MPG's that the Ram 1/2 Ton diesel does! Not even close! LOL
  #71
Old 01-06-2014, 09:58 AM
Tom's Avatar
Tom
Tom is offline
Very true, Motor Trend saw a consistent 28 MPG out of a regular cab 2WD EcoDiesel truck. But the EB doesn't carry a $4,000 price premium or any of the diesel headaches either. Tradeoffs for everything I guess.
If Ram rated the EcoDiesel to tow 11,000 lbs in crew cab form I would definitely take a hard look. It has plenty of power for that much weight, but I don't see it happening.
  #72
Old 01-06-2014, 12:05 PM
Frdtrkrul's Avatar
Frdtrkrul
Wish these engineers would actually put a worth while option in (ie manual transmission). $4000 for a V6 diesel top of another $500 mandatory for an 8 speed automatic. I want to know what the longevity is on that VM Motori engine is.
Least the mileage is good between the Hemi and the diesel. The extra expense in this case would end up coming ahead on the diesel after a few years.
  #73
Old 01-06-2014, 12:13 PM
Go Big or Go Home!
keep in mind that all Ford,Chevy,Ram are advertising is great gas mileage and will be the campaign moving forward..MPG's. Reliable/Durable,, that another story..All I can say is get the longest warranty you can buy.
  #74
Old 01-06-2014, 12:14 PM
Tom's Avatar
Tom
Tom is offline
Meh, manual transmissions had lackluster sales for years before they were finally killed off. I believe the take rate on Fords was in the low single digits in their best years in recent memory.
The old adage, "If you build it they will come" just doesn't apply to hand shakers.
  #75
Old 01-09-2014, 02:54 AM
supeRobertduty's Avatar
supeRobertduty
supeRobertduty is offline
That's so true, everybody loves the sticks but nobody ever buys them. Even the sports car market is changing with all the new auto/manual tip slap paddle rev match and so on
Quick Reply: 2015 F-150
