Explorer 8.8 Rear End - Page 2 - Ford Truck Enthusiasts Forums
Old 01-08-2014, 07:24 PM
dferrell5 dferrell5 is offline
dferrell5 is starting off with a positive reputation.
RimRock,
Yes I am referring to pinion offset. His concern is the challenge of getting the motor (and I guess transmission) in the truck at the right angle to line up with the rear end.
Old 01-08-2014, 07:30 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Here is my 8.8, it is offset some but not a big deal. A lot of people run them and so far I haven't heard anyone who has had problems with it being off the center line by a few inches. And I don't think that you need to angle the motor/trans to make it work.
Old 01-08-2014, 10:39 PM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
Here is a couple photos from under my truck. You can see the offset. A link to pinion offset and angle.DRIVE LINE PHASING
Old 01-09-2014, 07:42 AM
fun-ford's Avatar
fun-ford fun-ford is offline
fun-ford is starting off with a positive reputation.
I have put almost 25,000 miles on mine,no problems caused by the offset pinion.
Old 01-09-2014, 08:11 AM
8.8 Rear end Pinion Offset
Mike,
Thanks for the photos, they will be really useful when talking to my builder. Does the fact that you have a 51 alter or change your thoughts that this should work given your truck demimsions are not the same as mine? I do however, no that Ben and otheres on here that have 48-50 have used this same rear end with great success. I am really hoping that we can work this out, I really want this posi rear end in my truck.
Old 01-09-2014, 08:29 AM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Derek,
We've got 10,000 miles on our's - no issues.
The 8.8 rear axle swap is the easy one. Wait till he get's to the front
axle replacement. Now that one took some effort & involved cutting into the frame & some pretty exact measurements. The front suspension replacement is not for the faint of heart.
Having Posi traction is nice. I've got one car that's not posi - my wife's afraid to pull it up our steep driveway - doesn't like the rolling backward thing.
Good luck over there in San Antonio.
Ben in Austin
1950 F1
Old 01-09-2014, 09:28 AM
Rimrock F1's Avatar
Quote:
Originally Posted by dferrell5 View Post
Mike,
Thanks for the photos, they will be really useful when talking to my builder. Does the fact that you have a 51 alter or change your thoughts that this should work given your truck dimensions are not the same as mine? I do however, no that Ben and others on here that have 48-50 have used this same rear end with great success. I am really hoping that we can work this out, I really want this posi rear end in my truck.
Derek, the link in my post gives good info on this. Pinion offset is no different that pinion angle and since the engine and the rear pinion shaft should be installed parallel with the frame you don't even have to set "angles" like you do when setting pinion angle. Hope this makes sense. Here is a diagram the one on the left (A) is wrong, on the right (B) correct. This shows the engine offset but would be the same with pinion offset.
Old 01-12-2014, 07:59 PM
Scot's Avatar
Scot Scot is offline
Scot is starting off with a positive reputation.
I would run the factory traction bars if I could make it fit. You need to duplicate the factory geometry as much as possible in order to not have the bar fighting the springs.
Old 01-13-2014, 07:39 PM
Builder seems to think that the issue might be more exacerbated in my case because I am running a SBC and not a Ford power plant. Anyone with a SBC and 8.8 have any advice?
Old 01-14-2014, 11:51 AM
drptop70ss's Avatar
drptop70ss drptop70ss is online now
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Time to find a new "builder".
Old 01-14-2014, 12:01 PM
DougofMontana's Avatar
DougofMontana DougofMontana is offline
DougofMontana is starting off with a positive reputation.
I'll be keeping an eye out for the responses as well, as I'm considering this rear end for my '49.
Old 01-14-2014, 12:06 PM
Wayne Waldrep's Avatar
Wayne Waldrep Wayne Waldrep is offline
Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.
Quote:
I totally agree and was waiting for someone else to post it...lol. Two points that you can either accept or choose not to...
1) MANY people are running the explorer rear and have posted here telling you IT WORKS FINE. These people have actual experience and are good folks so I know they are telling you honest info.
2) any "builder" that thinks a driveshaft will magically "know" that it's inserted into a chevy versus ford tranny is on something. RUN!!!! A chevy tailshaft or a ford tailshaft for this purpose/situation make NO difference as far as lining up or slightly off compared to the rear end.
Not trying to be short or rude but some of the "builder comments" are so out there I feel like you are asking for trouble dealing with him. Just trying to help. I hope you take no offense.
  #28
Old 01-14-2014, 02:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
+1... Since he is clearly clueless on this aspect of the "build", I'd grill him closely on what angle he is setting the perches/pinion at. Make sure he is setting the axle so the perches are equal distances from the end flanges, not the pinion. I wouldn't trust him, to be honest.
  #29
Old 01-15-2014, 06:30 PM
Well,
After talking to my guy and sharing with him what you guys have shared with me, we are back on track and believe we can make the rear end work. AS many of you have said, I couldn't understand if so many of you have done this, then it was possible. Will provide more infer as we prepare to install motor and transmission early next week. Thanks to all!!!!!
  #30
Old 01-15-2014, 06:34 PM
drptop70ss's Avatar
So, you had to convince your "builder" that it could be done? Are you paying this person? Are you doing a complete truck build or just swapping the rear? I hope this works out for you but I would of run away already.
crown vic front end with explorer 8.8 rear end kevintoupin 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-15-2016 10:05 PM
Ford Explorer 8.8 rear axle abrauer 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 11-16-2009 01:21 PM
Ford 8.8 Rear Axle Assembly - Differences cher96 Explorer, Sport Trac, Mountaineer & Aviator 7 06-08-2009 12:01 PM
Axle Swap oldbluebronco 1978 - 1996 Big Bronco 4 03-05-2008 11:57 AM
Aerostar rear Axle donor (it's an 8.8)? boilerbots 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 09-28-2005 09:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
